Consistent Compile Issue - Please advise
cclough
PostPosted: Sat Oct 14, 2006 1:54 pm     Reply with quote
Greetings all,
I'm still pretty fresh to the PIC C scene, so please bear with me.
I can't seem to get it to compile due to a the error 'A numeric expression must appear here' on the
else if ((input(PIN_B0)) = 0)
Am I missing something totally obvious here? I've done something similar to this above and it works fine.
Any input would be great.
Thanks,
-Chris
#include <10F202.h>
#fuses NOWDT                              //WDT Disabled
#fuses NOMCLR                              //Master Clear Disabled
#fuses NOPROTECT                            //Code Protected from reads
#use delay(clock=4000000)                     //4MHz Clock
#use fast_io(B)                               //Otherwise the compiler will want to control the TRIS
//*** Pin Definitions ***//
//GPO = Start In
//GP1 = ICSPCLK (unused)
//GP2 = Start Out
//GP3 - MCLR (MCLR disabled, 12.5V to prog)
   int1 flag = 1;                            //Flag to determine if read matches 'secret'
   int1 auth = 0;                            //Flag for state changes
   int1 samp=0;                              //Indicates determined pulse sample
   int i,x;                                //For loops
   int read[8];                              //Read byte from pulse train
   int secret[8] = {0,0,0,1,1,0,0,0};             //Byte for read comparison
   set_tris_b(0b11111001);                    //Set GP0 as input
   output_high(PIN_B2);                       //Set GP2 initially high
          if((input(PIN_B0)) && (auth=0))         //If B0 goes low AND auth flag is 0
            for(x=0;x=7; x++)
               delay_us(100);                   //Delay between bits in pulse train
               for (i=0;i=3;i++)             //Sample three times to determine bit
                  samp=input(PIN_B0);
                  samp=samp+samp;
               if (samp<1>=2)
                  samp=1;
               read[x]=samp;                  //Put sampled bit into array
            for(x=0;x=7;x++)
               if ((read[x])==(secret[x]))      //Compare sampled byte to known byte
                  flag=flag&&1;            //If sampled and known are equal, make Flag AND 1
                                        //if not equal, return to top
            if (flag==1)                  //If sampled byte was equal
               output_low(PIN_B2);            //Set GP2 low (enable START relay)
               auth=1;                     //Set auth flag to disable sample
         else if ((input(PIN_B0)) = 0)         //If B0 goes high
            output_high(PIN_B2);            //Set GP2 high (disable START relay)
            auth=0;                        //Set auth flag to allow for sample loop to start if
}                                       //GP0 goes low again
lewiseley
PostPosted: Sat Oct 14, 2006 2:09 pm     Reply with quote
perhaps
else if ( input(pin_b0)==0)
cclough
PostPosted: Sat Oct 14, 2006 2:12 pm     Reply with quote
Hello - thanks for the reply.
I've tried this as well; same error :(
PostPosted: Sat Oct 14, 2006 2:43 pm     Reply with quote
Your code has many errors in it. This isn't really a C learning forum.
But to at least get your code to compile without errors, you need to
add braces as shown below.
if(flag==1)
   output_low(PIN_B2);
   auth=1;
else if ((input(PIN_B0)) == 0)
   auth=0;
I don't want to go through your whole code and fix all the errors.
cclough
PostPosted: Sat Oct 14, 2006 2:56 pm     Reply with quote
I appreciate your response, but did you need to add the criticism?
Your suggestion was helpful, and allowed me to compile. Thank you.
I'd love a critique of the code, if you're open to spending a few minutes to look it over.
-Chris
PostPosted: Sat Oct 14, 2006 3:14 pm     Reply with quote
The biggest problem, is failure to bracket. C, does not magically understand what you want it to execute from a 'test'. It executes just the very next _statement/block_. If you want multiple lines to execute, then _you_ need to bracket the lines to form a single statement block.
So for example:
    //This line _alone_ is executed by the while loop
        //If the test is true, this line gets executed
        for(x=0;x=7; x++)
           //Which executes this line
        //We get here, if the 'if' fails
             //when the 'for' is executed, it runs this line
             samp=input(PIN_B0);
             //but not this one...
             samp=samp+samp;
PostPosted: Sat Oct 14, 2006 4:04 pm     Reply with quote
I debated whether or not to put that in.
The reason for all my comments was this thread earlier in the week.
http://www.ccsinfo.com/forum/viewtopic.php?t=28403
I tried to help someone with similar types of errors in their code,
such as a mis-understanding of how to use braces.
That thread went on for two pages. I would suggest changes.
The person would make a few of them. I would ask the person to
please review their code and fix all bugs of the type that I pointed out.
The person would never really completely do it.
I don't want to get caught up in a thread like that again.
cclough
PostPosted: Sat Oct 14, 2006 8:22 pm     Reply with quote
PCM: I figured there was another situation that sparked the statement; thank you for help.
Ttelmah: Thank you for the brief explanation.
I went through and put the brackets in the way they should be, and now things compile, and it's bouncing between statements properly. It doesn't work the way I want it to, but at least it's doing something. Wink
PostPosted: Sun Oct 15, 2006 5:00 am     Reply with quote
One other error repeating in our code is the use of '=' for comparing values. A single '=' sign will assign a value, the correct way to compare a value is by using the '==' statement. Sometimes this is done correctly in your code but not always, for example all for-loops contain this error and there are more.
cclough
PostPosted: Sun Oct 15, 2006 9:02 am     Reply with quote
Thanks for point this out. I fixed the for-loops already, but need to go through and deal with the others.
-Chris
