what wrong with rs232
ryan.reeve
PostPosted: Sat Oct 14, 2006 1:33 am     Reply with quote
Whats wrong with this code.i cant get any character from the serial port.
#include<stdio.h>
#include<stdlib.h>
#include<string.h>
#define SIZE 80
#define CR 0x0d
#define COMMA 0x2C
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7, stream=GPS)
void parse();
void rmc();
void gga();
unsigned int j,k;
unsigned char *pChar,LastComaPos;
unsigned char inStr[SIZE] ;
unsigned char c;
int8 index=0;
#INT_RDA
void gps_isr(void)
 c =fgetc(GPS);
 printf(lcd_putc,"\%c",c); //just for debugging
 if(c=='$')
   inStr[index]=c;
   index++;
   if (index==CR) index=0;
    lcd_init();
    WHILE(TRUE)
      parse();
void parse()
   if(inStr[0]!='$')
    printf(lcd_putc,"No Valid Data");
   if(inStr[3]=='R' && inStr[4]=='M' && inStr[5]=='C')
      rmc();
    else if(inStr[3]=='G' && inStr[4]=='G' && inStr[5]=='A')
          gga();
PostPosted: Sat Oct 14, 2006 2:02 am     Reply with quote
At a minimum, you need to enable INT_RDA interrupts and also
GLOBAL interrupts.
Use the program in this post as a guide:
http://www.ccsinfo.com/forum/viewtopic.php?t=27156&start=1
