LCD Contrast regulated by a PIN
Acktung
PostPosted: Sat Jun 18, 2005 6:13 pm     Reply with quote
is possible?
... is there someone whom he knows how to regulate ana analogical tension on a pin? in this way it would be possible to check the contrast of a lcd eliminating the use of the trimmer ...
kender
PostPosted: Sun Jun 19, 2005 1:05 am     Reply with quote
You can connect a pin to an RC filter, and then pulse-width modulate the digital signal on it. You'll have a primitive DAC.
PostPosted: Sun Jun 19, 2005 4:29 am     Reply with quote
Key thing to remember, is that on most LCD's, the contrast control is a -ve voltage. This means that if you use a PWM DAC, or any other form of simple DAC, you end up needing a voltage shifter circuit afterwards.
However some digital potentiometer chips, will support voltages on the pot, beyond the supply rails. I use the X9C503, to control the contrast on a number of projects. This supports terminal voltages down to -5v, and have the big plus that the chip itself stores the last set position on power down. We have a bit of code that during the first ten seconds after power up, alows two keys normally used for other operations, to change the pot value.
libor
PostPosted: Sun Jun 19, 2005 4:31 am     Reply with quote
you can also use digital potentiometer ICs for a really fancy LCD contrast setting. These are available from Microchip as MCP4021 /2/3/4, (or many others from different manufacturers), these usually have up/down control, last value saved, and many other features.
PostPosted: Sun Jun 19, 2005 6:57 pm     Reply with quote
I don't think this is true for modern character LCDs. I checked the
data sheets for 16x2 LCDs from various manufacturers, and all of
them will work with a contrast control that consists of a 10K trimpot
connected between +5v and GND.
CrystalFontz:
The 16x2 Data Sheet shows a trimpot connected to +5v and GND.
They show an optional Vee generator, but I have used a CrystalFontz
LCD and I know that a positive voltage for the contrast voltage works OK.
The notes on my schematic say that 0.425v gives the best contrast on
a 8x2 LCD.
http://www.crystalfontz.com/products/1602b/index.html#CFAH1602BYYBJP
Comment on their tech forum that says contrast voltage is positive:
http://www.crystalfontz.com/forum/showthread.php?
s=7b92e998cbb9eb1559d4d7b1facde2b3&threadid=2281
Hantronix:
Page 6 of the specification for their Character LCDs shows a trimpot
connected between +5v and GND. They show an option of using Vee,
but I have used Hantronix LCDs and I know that the positive-voltage
method works OK.
http://www.hantronix.com/down/char-comm.pdf
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
Hi, Ttelmah , can you post the "driver" code for X
PostPosted: Thu Oct 12, 2006 12:32 pm     Reply with quote
Hi, Ttelmah (or anyone) , can you post the "driver" code for X9C503 you used to control contrast ?
Thank you ALL
Mark Weir
PWM
PostPosted: Thu Oct 12, 2006 12:56 pm     Reply with quote
Hi There ,
I have had great success just using the on board PWM module and adjusting the duty cycle to give the desired contrast here is an example.
setup_timer_2(T2_DIV_BY_16,250,1);  //Timer2 enabled, prescaler of 1, PR1 = 250, post-scaler = 5
setup_ccp1(CCP_PWM);
set_pwm1_duty(10);
I use this example with both 16 F 872 and 18 F 252 PIC's.
I connect pin C2(ccp1 out) to pin 3 ( Vee) on the lcd then adjust the value in set_pwm_duty to suit.
Hope this helps.
Cheers
Mark
C Turner
PostPosted: Thu Oct 12, 2006 1:13 pm     Reply with quote
In line with a previous reply of mine, I might point out that many surplus/new LCDs that will work with a 0-5 volts contrast voltage have very high input impedance on their contrast adjust pins. This would make them pretty good candidates for using the CVref pin (as mentioned in the "is it possible to output an analog voltage on an analog pin" thread) to control the contrast.
In my experience, most LCDs have the majority of their useful range "scrunched" near one end of the adjustment (the GND end, I believe) so this is a case where it might be beneficial to use a resistive divider (or even heavily load the R-2R network) to move the D/A range closer to GND. Having only 4 bits (16 steps) of adjustment should be enough for LCDs, too...
CT
PostPosted: Thu Oct 12, 2006 2:36 pm     Reply with quote
Yes. In fact I am using a couple of the Powertronic ones, with the simplest possible contrast control. Resistor/capacitor from a PWM output. Runs very well indeed.
