Using the Encoder Quadrature - QEI - PIC18F2431
Mauricio Lopes
PostPosted: Wed Oct 11, 2006 11:59 am     Reply with quote
How i do to use this module in CCS C compiler? Somebody have an exemple to send-me?
Best Regards,
Mauricio Lopes
sd211
PostPosted: Tue Oct 17, 2006 6:48 pm     Reply with quote
Here is some code related to setting up QEI, I used it while ago. I could not find a function in CCS C to set it up, but this seemed to work:
In include file:
//Defines specific for 18F2431 which are not present in 18F2431.H file
//bits of QEICON Quadrature Encoder Interface control register
#define     DISABLE_VELOCITY    0x80
#define     QEI_OFF                    0x00
#define     QEI_2XINDX              0x04
#define     QEI_2XPER                0x08
#define     QEI_4XINDX              0x14
#define     QEI_4XPER                0x18
#define     VELOCITY_DIV_1       0x00
#define     VELOCITY_DIV_4       0x01
#define     VELOCITY_DIV_16     0x02
#define     VELOCITY_DIV_64     0x03
#byte       QEICON = 0xFB6
//bits in QEICON
#define     QEI_NOT_VELM          7
#define     QEI_ERROR               6
#define     QEI_DIRECTION        5
int16       POSCNT;
#byte       POSCNT    = 0xF66
#byte       POSCNTH  = 0xF67
#define     POSCNTL  = 0xF66
int16       VREG;
#byte       VREG        = 0xF68
#byte       VREGH      = 0xF69
#byte       VREGL       = 0xF68
#byte       DFLTCON   = 0xF60   //Digital Filter Control Register
#byte       CAP1CON  = 0xF63
in the .c file (initialization):
//setup quadrature encoder
QEICON = QEI_2XINDX | VELOCITY_DIV_4;
QEICON &=0b01111111;      //clear Velocity mode bit to enable
CAP1CON |= 0b01000000;   //enable Time Base reset (TMR5)
                            //TMR5 used for velocity measurement
setup_timer_5 (T5_INTERNAL | T5_DIV_BY_4);
enable_interrupts(INT_IC1);
enable_interrupts(INT_IC2QEI);
enable_interrupts(INT_IC3DR);
And then process interrupts somewhere
#int_IC1
   Velocity capture interrupt
void IC1_isr()
#int_IC2QEI
   Position counter interrupt
   Increment (decrement) variable MSB_position that provides a 32-bit position
   counter along with hardware position counter
void IC2QEI_isr()
#int_IC3DR
   Direction of movement interrupt
void IC3DR_isr()
Hope this helps
Sergey Dryga
http://beaglerobotics.com
Mauricio Lopes
PostPosted: Wed Oct 18, 2006 8:36 pm     Reply with quote
Very Thanks Mr. Sergey,
It works very good... Its all thats i need Laughing
Best Regards,
Mauricio Lopes
hasimi20
PostPosted: Sun Apr 24, 2011 7:31 pm     Reply with quote
hello, by using sd211's code, how can i determined the encoder direction and encoder speed??i still cant understand how to use the given code. could any body please share how to program the qei module in order to determined the encoder direction and encoder speed??
scottc
PostPosted: Mon Apr 25, 2011 9:27 am     Reply with quote
Hi, here is a link to a worked example that you can try out
http://www.ccsinfo.com/forum/viewtopic.php?t=44768
Thanks Scott
hasimi20
PostPosted: Tue May 03, 2011 12:35 am     Reply with quote
I am using ccs c compiler pcwhd 4.104. I am testing your given program, however the compiler can't compile the "setup_qei(QEI_MODE_X2);"... could you please explain???
PostPosted: Tue May 03, 2011 12:29 pm     Reply with quote
Your version of the compiler (4.104) doesn't have support for the
setup_qei() function. He is using a later version (4.116).
