Use of bit fields
Akutabi
Use of bit fields
PostPosted: Wed Oct 11, 2006 7:55 am     Reply with quote
Is it possible to use bit fields with CCS ?
In C ANSI, bit fields are used like this :
struct {
short x:5, y:4, z:7;
}data;
struct data my_data;
my_data.x = ....
my_data.y = ....
my_data.z = ....
So, is it possible to to do the same with CCS ?
Thanks,
PostPosted: Wed Oct 11, 2006 8:13 am     Reply with quote
Yes. Bit fields are part of standard C (not just ANSI C), and CCS follows the 'norm' with this. However there is a restriction. Since the default data type is an 8 bit integer, the field 'boundaries' have to fit inside this. As shown, it'll fail, since a 5 bit field, plus a 4 bit field, and a 7 bit field will not fit into an 8 bit field.
