16 bit pointer write problem
PostPosted: Tue Oct 10, 2006 9:47 am     Reply with quote
Just trying to write a 16 bit value from a called function via a pointer. I have defined *=16 to use 16 bit pointers. It appears that only the lower 8 bits are being written when using the following code. The upper byte is left unchanged in program memory. What do i need to do to write the full 16 bits??
Thank you!
#include <16F877>
#device *=16
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT,NOPROTECT,NOWRT,NOCPD
void point_back_long(a,b,c,d){
delay_cycles(1);
*a=4;
*b=65535;
*c=65535;
*d=65535;
void main(){
int16 a=3,b=256+3,c=512+3,d=1024+3,e=65535;
delay_ms(50);
#ifdef use_lcd
lcd_init();
//printf(lcd_putc,"\fa before: %lu",a);
delay_cycles(1);
point_back_long(&a,&b,&c,&d,&e);
delay_cycles(1);
//printf(lcd_putc,"\na after: %lu",a);
PostPosted: Tue Oct 10, 2006 10:33 am     Reply with quote
To simplify the question, Can i write a 16 bit value value using a pointer? If so how?
PostPosted: Tue Oct 10, 2006 12:01 pm     Reply with quote
I'm surprised your code compiles without error (but the CCS compiler is known not to be very strict).
I didn't test the result, but at least you should fix the following:
Change
to
void point_back_long(int16 *a, *b, *c, *d){
PostPosted: Tue Oct 10, 2006 12:12 pm     Reply with quote
All of the parameters have to be declared as int16* (not just the 1st one).
Example:
#include <16F877.h>
#fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
void point_back_long(int16 *a, int16 *b, int16 *c, int16 *d)
*a = 4;
*b = 0xFFFF;
*c = 0xFFFF;
*d = 0xFFFF;
int16 a = 3;
int16 b = 0x103;
int16 c = 0x203;
int16 d = 0x403;
printf("Before:\n\r");
printf("a = %LX\n\r", a);
printf("b = %LX\n\r", b);
printf("c = %LX\n\r", c);
printf("d = %LX\n\r", d);
printf("\n\r");
point_back_long(&a,&b,&c,&d);
printf("After:\n\r");
The output of the program is:
Before:
a = 0003
b = 0103
c = 0203
d = 0403
After:
a = 0004
b = FFFF
c = FFFF
d = FFFF
PostPosted: Tue Oct 10, 2006 12:21 pm     Reply with quote
Thank you very much for the feedback and the time in running the program. That did the trick. As always you rock, PCM!
PostPosted: Tue Oct 10, 2006 1:20 pm     Reply with quote
You are right PCM. I've been programming to long in Delphi and was confused by classic C where we wrote
void point_back_long(a, b, c, d) int16 *a, *b, *c, *d;
PostPosted: Tue Oct 10, 2006 11:00 pm     Reply with quote
Hi ckielstra,
I wasn't trying to upstage you. I had spent a few minutes
making that test program when I noticed that you had already
replied. I felt like since I put in so much time on it, I might
as well post it.
