make8 usage
make8 usage
PostPosted: Tue Oct 10, 2006 6:15 am     Reply with quote
can anybody see what i am doing wrong down here.
i am tring to store a 16bit number in eeprom by splitting it using make8, so i tried the following;
int MSB, LSB
INT16 ADC
MSB = make8(ADC,0);
LSB = make8(ADC,1);
printf(lcd_putc("%UL-%U-%U",ADC,MSB,LSB));
the output from the above code will be;
ADC = 1320
MSB = 40
LSB = 5
Can anybode see why i am getting some strange numbers here??
Thanks, Nick
JPA
PostPosted: Tue Oct 10, 2006 8:58 am     Reply with quote
You inverted MSB and LSB... See compiler function references for the use of make8.
