.lst file out of order a few lines
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Oct 10, 2006 8:58 am     Reply with quote
A strange thing is happening. The .lst file is a few lines displaced from the source code. This causes breaks to be placed in the incorrect location! Is this a bug? For example here is a simple function:
.................... * read_id
.................... * Purpose: Reads the ID of the unit
.................... void read_id() {
001A0:  BCF    F9E.6
001A2:  GOTO   0080
.................... int1 dummy;
....................    output_high(LSBGAIN);
....................    output_float(MSBGAIN);
003D4:  BCF    F9A.6
003D6:  BSF    F91.6
....................    if (input(MSBGAIN)) bit_set(IREGISTER,7);
003D8:  BSF    F9A.7
003DA:  BSF    F9A.7
003DC:  BTFSC  F88.7
003DE:  BSF    47.7
....................    output_high(MSBGAIN);
....................    output_float(LSBGAIN);
003E0:  BCF    F9A.7
003E2:  BSF    F91.7
....................    if (input(LSBGAIN)) bit_set(IREGISTER,6);
003E4:  BSF    F9A.6
003E6:  BSF    F9A.6
003E8:  BTFSC  F88.6
003EA:  BSF    47.6
....................    output_low(LSBGAIN);
003EC:  BCF    F9A.6
003EE:  BCF    F91.6
....................    if (input(MSBGAIN)) bit_set(IREGISTER,5);
003F0:  BSF    F9A.7
003F2:  BSF    F9A.7
003F4:  BTFSC  F88.7
003F6:  BSF    47.5
....................    output_low(MSBGAIN);
003F8:  BCF    F9A.7
003FA:  BCF    F91.7
....................    if (input(LSBGAIN)) bit_set(IREGISTER,4);
003FC:  BSF    F9A.6
.................... } // read_id
003FE:  BSF    F9A.6
00400:  BTFSC  F88.6
00402:  BSF    47.4
00404:  RETLW  00
PostPosted: Tue Oct 10, 2006 11:51 am     Reply with quote
Post your compiler version and a short, but complete demo program.
The program should be "drop in" compilable into MPLAB, with no
changes required.
