Scottl
Need help first timer! |
Posted: Mon Oct 09, 2006 7:39 pm |
I have just started using the PCWH Compiler. I have a simple application that seems to run one time then stops. I cannot get it to continue running. Here is some of my code if someone can point out what I am doing wrong it would be greatly appreciated. I get everything on my website one time then I must reset the board then it sends the data once then stops.
init(); // Configure peripherals/hardware
while(1) // Continuous loop
for (loops=0; loops<=1; loops++)
for (channel=0; channel<=7; channel++) // A/D channel select 0 to 3
set_adc_channel( channel ); // Set A/D channel
delay_us(20);
ad = read_adc(); // Read A/D channel into ad variable
volts = (float)ad * (5.0/1023); // Convert 10-bit reading
Show_AD(); // Show results as channels A,B,C,D
delay_ms(1067);
goto connect;
connect:
printf( "CXXX.XXX.XXX.XXX/80\n" ); // connect to my webserver
inbyte = getch(); // Get C for connected
if (inbyte == 'C') // IF C send data
printf( "GET /XXX/XXX.php?site=" );
printf( "%ld", inc );
printf( "&an1=%01.3f",ad_0 );
printf( "&an2=%01.3f",ad_1 );
printf( "&an3=%01.3f",ad_2 );
printf( "&an4=%01.3f",ad_3 );
printf( "&an5=%01.3f",ad_4 );
printf( "&an6=%01.3f",ad_5 );
printf( "&an7=%01.3f",ad_6 );
printf( "&an8=%01.3f",ad_7 );
printf( " HTTP/1.0\n\n");
printf("Host: www.XXXXXXXX.com");
goto stepout;
else if (inbyte == 'N') // If N Try again
goto connect;
else // Anything else stepout try later
goto stepout;
stepout:
delay_ms(5000); // Wait 5 seconds
inc = inc + 1; // Increment
if ( inc > 15000 )
inc = 0;
} // Do it again!
Posted: Mon Oct 09, 2006 11:21 pm |
I don't know what your code is supposed to do, but I made it into
a test program, made a few changes and got it to produce some output.
It displays the following:
Start
CXXX.XXX.XXX.XXX/80
GET /XXX/XXX.php?site=0
&an1=0.000
&an2=1.000
&an3=2.000
&an4=3.000
&an5=4.000
&an6=5.000
&an7=6.000
&an8=7.000
HTTP/1.0
CXXX.XXX.XXX.XXX/80
GET /XXX/XXX.php?site=1
&an1=0.000
&an2=1.000
&an3=2.000
&an4=3.000
&an5=4.000
&an6=5.000
&an7=6.000
&an8=7.000
HTTP/1.0
CXXX.XXX.XXX.XXX/80
GET /XXX/XXX.php?site=2
&an1=0.000
&an2=1.000
&an3=2.000
&an4=3.000
&an5=4.000
&an6=5.000
&an7=6.000
&an8=7.000
HTTP/1.0
CXXX.XXX.XXX.XXX/80
Etc.
The changes I made were:
1. Your code has some large delays in it. You go through a
loop 16 times, and delay for about 1 second each time.
The program will appear to be locked up during this time.
Then down at the bottom, you've got another 5 second delay.
I greatly reduced all those delays.
2. Most of your printf() statements don't have a carriage return-
linefeed after them, so they didn't display properly in my
serial terminal window. I fixed that by adding "\n\r" at the end
of most printf statements.
3. You didn't show any variable declarations. I declared them all
in what seemed to be the most logical data type, based on the
usage.
4. I put in stubs for the routines that you didn't show in your post.
I also put in the #include, #fuses, and #use statements.
5. Your code waits for a 'C' character. I don't know if this comes from
some device or if you are typing it in. If you type it in, then because
you're only checking for a capital 'C', the program won't respond to a
lower case 'c' if that character is typed in. This could also be a reason
why the program would appear to be "locked up". I always made
sure that I typed in a capital 'C'.
You have several other things in there, such as 'goto' statements, that
should be removed. The code should be written in a different way so
they aren't needed.
#include <16F877.H>
void init(void)
void show_AD(void)
int8 loops;
int8 channel;
int8 ad;
int8 inbyte;
float ad_0 = 0.0;
float ad_1 = 1.0;
float ad_2 = 2.0;
float ad_3 = 3.0;
float ad_4 = 4.0;
float ad_5 = 5.0;
float ad_6 = 6.0;
float ad_7 = 7.0;
int16 inc = 0;
float volts;
printf("Start\n\r");
for(loops=0; loops<=1; loops++)
for(channel=0; channel<=7; channel++) // A/D channel
delay_us(20);
// goto connect;
connect:
printf( "CXXX.XXX.XXX.XXX/80\n\r" ); // connect to webserver
if(inbyte == 'C') // IF C send data
printf( "GET /XXX/XXX.php?site=\n\r" );
printf( "%ld\n\r", inc );
printf( "&an1=%01.3f\n\r",ad_0 );
printf( "&an2=%01.3f\n\r",ad_1 );
printf( "&an3=%01.3f\n\r",ad_2 );
printf( "&an4=%01.3f\n\r",ad_3 );
printf( "&an5=%01.3f\n\r",ad_4 );
printf( "&an6=%01.3f\n\r",ad_5 );
printf( "&an7=%01.3f\n\r",ad_6 );
printf( "&an8=%01.3f\n\r",ad_7 );
printf( " HTTP/1.0\n\r");
printf("Host: www.XXXXXXXX.com\n\r");
goto stepout;
goto connect;
goto stepout;
stepout:
delay_ms(1000); // Wait 5 seconds
if( inc > 15000 )
inc = 0;
} // Do it again!
