Read_eeprom and write_eeprom error with 18F452 & Ver3.24
hansolo
PostPosted: Sun Oct 08, 2006 1:35 am     Reply with quote
I tried using the following commands with PIC18F452 and compile with PICC V3.249.
read_eeprom();
write_eeprom();
The error I have got is :
Error[12]   D:\PICC Programs\Clock_Test_2.c 93 : Undefined identifier  -- write_eeprom
      1 Errors,  0 Warnings.
I have no problem compiling the same code with PIC16F877A.
I tried using the 2 commands above in other projects using PIC18F452 and have same error.
I think there is some bug with the PIC18F452 header file or something.
Any help is welcome.
PostPosted: Sun Oct 08, 2006 10:19 am     Reply with quote
The following program compiles with no errors, with PCH vs. 3.249.
Try it, and see you can compile it. If not, re-install the compiler.
That might fix the problem.
#include <18F452.h>
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
main()
int8 result;
write_eeprom(0, 0x55);
result = read_eeprom(0);
hansolo
PostPosted: Sun Oct 08, 2006 5:19 pm     Reply with quote
My mistake, I have use #include<18C452.h> instead of #include<18F452.h>. Embarassed
It seems that PIC18C452 does not have eeprom inside.
By the way, thanks for your assistance PCM.
Hansolo
