Fdummy=0;
while(TRUE){
if (kbhit(FP)){
Fresponse[Fdummy] == fgetc(FP);
if (Fresponse[Fdummy] == 0x0A){return 1;}
Fdummy++;
this is the code when i run this program Fdummy becomes 13 but the bytes of Fresponse array are 0. I use scobe and see that not all cycles are 0. My pic is 18f6722 and the clock is 3276800. is there problem at UART
drh
Joined: 12 Jul 2004 Posts: 192 Location: Hemet, California USA
Posted: Fri Oct 06, 2006 8:19 am
Change this:
To this:
Fresponse[Fdummy] = fgetc(FP);
and try it again. _________________ David
gnz Guest
Posted: Sat Oct 07, 2006 1:16 am
Thanks. I've noticed this a few minutes ago. But spent so much time on it.
