Why digit show 1 and 7 light show is more than 2,3,4,5,6,8,0
tsupuntu
PostPosted: Fri Oct 06, 2006 5:15 pm     Reply with quote
I used seven segment commom anote .
Why digit show 1 and 7 light show is more than 2,3,4,5,6,8,0 ?
ak6dn
Re: Why digit show 1 and 7 light show is more than 2,3,4,5,6
PostPosted: Fri Oct 06, 2006 6:34 pm     Reply with quote
Probably because you are using a single current limiting resistor at the common anode pin, rather than seven current limiting resistors, one at each of the cathode pins?
Just guessing here, you have not really provided enough information...
With seven resistors (one per segment) the segments should each illuminate at about the same brightness. WIth just one resistor, the more segments you turn on, the dimmer each will get ('1' will be brightest, '8' dimmest).
