Getting Garbage from RS-232
Zulander
PostPosted: Fri Oct 06, 2006 12:49 pm     Reply with quote
Hi, i am tring to get my PIC16F690 to commuicate with my PC using MAX232, i am able to connect to the PIC, all i am getting is garbage.. i am getting extended ASCII code... ican't find any information on solving the problem..
please help me!!!!
this is my code:
#include "C:\Documents and Settings\Rohan\Desktop\PicTest\test.h"
#bit C1=0x7.0
#bit C2=0x7.1
#bit C3=0x7.2
int xBlinker=0; // Create Variable
Int Xcounter=0;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_oscillator(OSC_8MHZ);
set_tris_a(C1);
set_tris_b(C2);
set_tris_c(C3);
while (Xcounter <=257)
xCounter+=1;
delay_ms(1);
//Create Auto switch !
if (xBlinker==0) {
printf("LED ON");
C1=xBlinker;
C2=xBlinker;
C3=xBlinker;
xBlinker=1;
} else if (xBlinker==1) {
printf("LED OFF");
C1=xBlinker;
C2=xBlinker;
C3=xBlinker;
xBlinker=0;
// printf("Hello World\n");
C1=1;
C2=1;
C3=1;
//delay_ms(1000);
// C1=0;
//C2=0;
// C3=0;
SherpaDoug
PostPosted: Fri Oct 06, 2006 1:28 pm     Reply with quote
Show us your full header including the #use RS232 line.
Your problem is likely either a wrong baud rate, which could be due to a wrong declairation or a bad clock, or wrong voltage levels like inversion or using TTL where you should use RS232 levels or vise versa. The best tool to troubleshoot these things is an oscilloscope.
Zulander
Header files
PostPosted: Fri Oct 06, 2006 1:39 pm     Reply with quote
This is the Header file..
#include <16F690.h>
#device adc=8
PostPosted: Fri Oct 06, 2006 2:41 pm     Reply with quote
What is your oscillator (crystal, or external module). You need a fuse setting for this. The default fuses for this will be for RC oscillator.
Douglas Kennedy
PostPosted: Fri Oct 06, 2006 2:44 pm     Reply with quote
First I'd forget your code and try the simplest possible code
main
while(true)
printf("x");
You've been advised to double check the baud rate etc to make sure the PC is no different.
If that doesn't work check the wiring from the xmt pin on the pic to the MAX232 and out to the RX pin on the PC.
Thousands can make this work so assume it is you're code and or your wiring and trple check if necessary.
PostPosted: Fri Oct 06, 2006 2:54 pm     Reply with quote
#bit C1=0x7.0
#bit C2=0x7.1
#bit C3=0x7.2
set_tris_a(C1);
set_tris_b(C2);
set_tris_c(C3);
The stuff shown in bold is totally incorrect. You've defined 3 bits on
port C, and then you're using those bit definitions to set TRIS on ports
A, B, and C. This is wrong. My advice is to get rid of all the #bit
statements and the set_tris statements and just use the CCS pin i/o
functions, such as output_low() and output_high().
Int Xcounter=0;
In CCS, an 'int' is an unsigned 8-bit integer. It can only hold a value
from 0 to 255. It can't hold 257. You need to declare the variable as
'int16'.
Zulander
Problem solved but does not help..
PostPosted: Wed Oct 11, 2006 9:48 pm     Reply with quote
I have managed to solve the problem, the problem was that my Bafo BF-810 USB to Serial (DB9) Adapter does not seem to be working for some reason, I was getting garbage. When I used a direct connection to a serial port it worked fine..
So does anyone know a solution for my problem?? I need to work on my laptop and I need a converter.. USB to serial
Thank you
