PCM & Multiple Source Files under MPLAB
Ray Livingston
PostPosted: Tue Aug 05, 2003 4:29 pm     Reply with quote
Using MPLAB 6.3, PCM 3.158: Is it possible to have multiple C source files? When I try, each module generates an error "Function referenced but not defined" on the all extern references. Because of these errors (which should not really be errors, as they are declared as extern....) the linker does not run.
Am I doing something wrong?
___________________________
Original Post ID: 144516691
Re: PCM & Multiple Source Files under MPLAB
PostPosted: Tue Aug 05, 2003 5:30 pm     Reply with quote
:= Using MPLAB 6.3, PCM 3.158: Is it possible to have multiple C source files? When I try, each module generates an error "Function referenced but not defined" on the all extern references. Because of these errors (which should not really be errors, as they are declared as extern....) the linker does not run.
It's not MPLAB. It's the compiler. It doesn't support
linking separate object modules together. You have to
#include all source modules in your main file. Then
compile it. See the following link for an example.
<a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/50.html</a>
Original Post ID: 144516693
TS
PostPosted: Tue Aug 05, 2003 7:24 pm     Reply with quote
:=:= Using MPLAB 6.3, PCM 3.158: Is it possible to have multiple C source files? When I try, each module generates an error "Function referenced but not defined" on the all extern references. Because of these errors (which should not really be errors, as they are declared as extern....) the linker does not run.
:=It's not MPLAB. It's the compiler. It doesn't support
:=linking separate object modules together. You have to
:=#include all source modules in your main file. Then
:=compile it. See the following link for an example.
:= <a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/50.html</a></a>
You are putting the C module files after the functions in the main file. Are you doing this so that if you use the modifier 'static' before a variable in a module (but not in a function in that module), it will have a scope limited to (will only be seen by) that module?
Original Post ID: 144516696
Mark
PostPosted: Tue Aug 05, 2003 8:49 pm     Reply with quote
There is but one and only one module for the CCS compiler. It doesn't really matter if you include them in the begining or end of the file.
:=:=:= Using MPLAB 6.3, PCM 3.158: Is it possible to have multiple C source files? When I try, each module generates an error "Function referenced but not defined" on the all extern references. Because of these errors (which should not really be errors, as they are declared as extern....) the linker does not run.
:=:=It's not MPLAB. It's the compiler. It doesn't support
:=:=linking separate object modules together. You have to
:=:=#include all source modules in your main file. Then
:=:=compile it. See the following link for an example.
:=:= <a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank"> <a href="http://www.pic-c.com/forum/general/posts/50.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/50.html</a></a></a>
:=You are putting the C module files after the functions in the main file. Are you doing this so that if you use the modifier 'static' before a variable in a module (but not in a function in that module), it will have a scope limited to (will only be seen by) that module?
Original Post ID: 144516699
Ray Livingston
PostPosted: Wed Aug 06, 2003 9:21 am     Reply with quote
OK, that's the conclusion I reached. Thanks! Is the same true for PCW?
Original Post ID: 144516714
PostPosted: Wed Aug 06, 2003 5:13 pm     Reply with quote
:=You are putting the C module files after the functions in the main file. Are you doing this so that if you use the modifier 'static' before a variable in a module (but not in a function in that module), it will have a scope limited to (will only be seen by) that module ?
I don't think that feature of the "static" keyword works
in CCS, because CCS doesn't support linkable object modules.
I put the C source files at the end of the main file because
they're out of the way, and it makes it look nicer.
Original Post ID: 144516733
PostPosted: Wed Aug 06, 2003 5:15 pm     Reply with quote
:=:=You are putting the C module files after the functions in the main file. Are you doing this so that if you use the modifier 'static' before a variable in a module (but not in a function in that module), it will have a scope limited to (will only be seen by) that module?
To TS:
Original Post ID: 144516734
