Christophe
Write data/files to a medium (USB stick, MM CARD..) via PIC |
Posted: Tue Oct 03, 2006 12:48 am |
I want to read a text/strings/data via a keyboard and then I want to save it on a medium. I was thinking about an USB stick.
How difficiult is it to implement that? Are there libraries available? I should be able to write data onto the stick and read data from the USB stick. Is it possible with a PIC, and which one? Do you have to write a driver?
Can it be done with the CCS development kit?
Are there any easier alternatives to implement with a PIC ? (I see SD cards come here frequently)
What is a good development kit for data logging on SD cards?
Some hints/tips on this one please, tks |
asmallri
Joined: 12 Aug 2004 Posts: 1642 Location: Perth, Australia
Re: Write data/files to a medium (USB stick, MM CARD..) via |
Posted: Tue Oct 03, 2006 1:39 am |
Christophe wrote: | Hi,
To do this you require the PIC to implement a USB host interface. All USB interfaces on the PIC are non host ports. You can get a Maxim USB host controller to connect to the PIC via the SPI bus. But there are far easier ways of doing what you want
Quote: |
Can it be done with the CCS development kit? |
No because it is not a USB host.
Quote: |
Are there any easier alternatives to implement with a PIC ? (I see SD cards come here frequently) |
Yes. SD/MMC cards interface to the PIC via the SPI bus. Electrically they are simple to interface - there is a trick, the SD/MMC cards are (generally) 3.3 volt interfaces and most PICs are 5 volts. If you check out the projects page on my web site you will find a number of (working) reference hardware designs to download that demonstrate how to connect reliably to an SD card. Becareful of some of the other PIC interface circuits you will find on the web as often they correctly handle the 5-to-3.3 for output liines to the SD card but fail to handle the SDI to the PIC from the SPI card. If this is not handled correctly you can find yourself with the problem that the cards appears to fail in obscure conditions.
Quote: | What is a good development kit for data logging on SD cards? | Microchip have a SD/MMC PICTail card but I have no used it.
Quote: | Some hints/tips on this one please, tks |
If you want the PC to be able to read the SD/MMC card using the standard fat file system then you will need both SD card drivers (available with CCS) and a Fat file system. There is a FAT file system in the CCS user download area however I spent a lot of time working with it but gave up on it.
Here is a link to another FAT filesystem implementation http://elm-chan.org/fsw/ff/00index_e.html
I have ported the ELM implementation the PIC and have modified it to reduce the memory footprint with the PIC and CCS, add some additional features I required, as well as dealing with compiler idiosyncrasies. I use my own SD drivers. I have been working with this implementation since July but have only recently got it to the stage where I can progress with my own data logger project. I plan to sell the source code for the port on my web site in the few couple of weeks once I have completed some performance and reliability testing. _________________ Regards, Andrew
Christophe
Posted: Tue Oct 03, 2006 1:50 am |
Thanks for your input; I thought that implementing an USB host would be hard.
This will be a project for students that come to make their thesis at our company.
What PIC do you advise for implementing MMC cards?
Are there any memory requirements? I've read that you have to write in 512 byte blocks; so having a lot of RAM would be welcome? |
asmallri
Posted: Tue Oct 03, 2006 2:01 am |
Quote: | Thanks for your input; I thought that implementing an USB host would be hard. This will be a project for students that come to make their thesis at our company. |
Well this will certainly sort out the good from the not so good :-)
Your reseach has hit the mark. The more RAM the better. Personally I would (and do) use 18F 2620/4620/8722 and variants that have 3900 bytes RAM. It is a waste of time using anything under an 18F series processor for SD/MMC cards if you want to implement a FAT file system. _________________ Regards, Andrew
Christophe
Posted: Tue Oct 03, 2006 2:19 am |
I also found this implementation:
http://chipdos.com/index.htm
Seems that this takes care of the fat file system overhead. What's the drawback with this one? Any experience?
Just exploring all the methods |
asmallri
Posted: Tue Oct 03, 2006 2:49 am |
Can't help with that one. I have not seen it before but it looks interesting. _________________ Regards, Andrew
Christophe
Posted: Thu Nov 02, 2006 4:38 am |
I have another question on the MMC interface.
What should be the supply voltage for the MMC cards? Is that 3,3V or can it be different, and how different? On what does that depend?
If the MMC supply is 3V3 and my PIC 's Vcc is 3V6; can I be able to communicate directly or is a voltage level converter required?
tks |
