Internal error
Thiago
Internal error
PostPosted: Mon Oct 02, 2006 6:36 pm     Reply with quote
Could you please help me in a question? i´m programming in C and i can compile this program till a determinated number of lines of my source code. if i write a little bit and compile again, it will make an error, an internal error. What kind of problem is this? my compiler is a free demo? what can be? i went to the help and saw: "This error indicates the compiler detected an internal inconsistency. This is not an error with the source code; although, something in the source code has triggered the internal error. This problem can usually be quickly corrected by sending the source files to CCS so the problem can be re-created and corrected."
i hope you help me...
PostPosted: Tue Oct 03, 2006 2:27 am     Reply with quote
The demo, has a size limit.
You are going over it.
