PIC16F628A connected to LM70( temperature Sensor)
wakaka
PostPosted: Mon Oct 02, 2006 7:59 pm     Reply with quote
IMHO, i think u can switch to lm35 for temperature sensor, user frenly, only 3 pins, output analog voltage with is propotional to the temperature. Can try tat........
PostPosted: Mon Oct 02, 2006 8:49 pm     Reply with quote
Hi Wakaka,
i Dont want to use LM35 because i will need A/D conversor.
If i use LM70 , a can conect without conversor A/D because i have digital output in this component.
jecottrell
PostPosted: Tue Oct 03, 2006 12:14 am     Reply with quote
Look at:
http://www.ccsinfo.com/forum/viewtopic.php?t=12407
http://www.ccsinfo.com/forum/viewtopic.php?t=17235
http://www.ccsinfo.com/forum/viewtopic.php?t=17567
That should give you some ideas. You may want to consider the I2C part mentioned in a couple of the posts. That may prevent you from having to write your own driver....
Good luck,
John
