Bug or misunderstanding of #locate?
asmallri
PostPosted: Mon Oct 02, 2006 1:25 am     Reply with quote
PCH Version PCH v3.243
Here is an extract of a symbol file
100-13F RxBaseSW
140-17F TxBaseSW
140-33F buffer
Note the two memory regions TxBaseSW and buffer overlap.
RxBaseSW and TxBaseSW are declared in an include file.
buffer is declared after the include file
Here are the relevant defines from the include file:
   // Define the size of the serial ring buffers
#define RxQsizeSW      64   // SW_UART Rx buffer size
#define TxQsizeSW      64   // SW_UART Tx buffer size
   // SW UART ring buffers
volatile byte   RxBaseSW[RxQsizeSW];   #locate RxBaseSW = 0x0100            // Rx buffer
volatile byte   TxBaseSW[TxQsizeSW];   #locate TxBaseSW = RxBaseSW + RxQsizeSW   // Tx buffer
Here is the declaration of buffer which is a global variable declared immediately after the include file statement
byte buffer[512];
I expected the use of #locate would have prevented the compiler from overlaying the address space of these global variables.
Regards, Andrew
PostPosted: Mon Oct 02, 2006 1:43 am     Reply with quote
I was able to duplicate your problem with PCH vs. 3.249.
I was able to fix it by using a constant for the base address.
Here are the results:
RxBaseSW      00000100
TxBaseSW      00000140
buffer        00000180
I think the compiler just wants to see a constant for #locate.
I don't think it can handle anything else. Here is the modified program:
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define ARRAY_BASE  0x100
#locate RxBaseSW = ARRAY_BASE
#locate TxBaseSW = ARRAY_BASE + RxQsizeSW
byte buffer[512];
asmallri
PostPosted: Mon Oct 02, 2006 1:53 am     Reply with quote
Thanks.
Regards, Andrew
