Radio module ER400xx
Inkwaterman
PostPosted: Wed Sep 27, 2006 3:09 am     Reply with quote
Hi !
Someone knows where I could find of the driver for radio module ER400xx ?
PostPosted: Wed Sep 27, 2006 5:24 pm     Reply with quote
You should use the forum's search page to search for ER400TRS.
Here is a link to the CCS search page:
http://www.ccsinfo.com/forum/search.php
Here is one of the threads that you will find by using the search page.
It has sample code. There are other threads as well. So do the search.
http://www.ccsinfo.com/forum/viewtopic.php?t=23886&highlight=er400trs
Also search http://www.google.com for the name of the product,
followed by some keywords from the C language. Example:
ER400TRS int char
By doing that search, you can find an article like this, that has C source
code. This article has CCS source code:
http://www.lprs.co.uk/pdf_directory/2386mylprs1124107109easy-radio-for-all.pdf
