		| Author | Message |
		| microccd
				| wrong state of pic16f876 |
				|  Posted: Tue Sep 26, 2006 3:40 pm |   |
				| I program and test the pic16f876, most of time, it works fine. but sometime when I turn on the power switch, it was in wrong state(wrong output). I shut it down then turn it on again, it will have the correct output. what may cause that? thanks a lot! |  |
		| PCM programmer
				|  Posted: Tue Sep 26, 2006 3:54 pm |   |
				|  	  | Quote: |  	  | But sometime when I turn on the power switch, it was in wrong state(wrong output) |
 Make sure you have the correct #fuses settings.   Make sure you
 have the ones shown in bold below:
 #include <16F877.H>
		| microccd
				|  Posted: Tue Sep 26, 2006 4:03 pm |   |
				| the following is what i'm using, are they correct?
  	  | Code: |  	  |
 #include <16f876.h>
 #device ICD=TRUE
 #fuses HS,NOWDT,NOLVP,PUT
		| PCM programmer
				|  Posted: Tue Sep 26, 2006 4:13 pm |   |
				| Did you read my post ?    Look at the item shown in bold below. Put it in your code !
 #include <16F877.H>
		| microccd
				|  Posted: Tue Sep 26, 2006 4:23 pm |   |
				| yes, but what's the function of BROWNOUT? thank you. |  |
		| PCM programmer
