leekp8
Flash program memory not working |
Posted: Mon Sep 25, 2006 11:12 am |
Can anybody help to look at he following codes as
after program I was not able to read out the correct
codes. I'm not sure if write or read problem.
This is checked in the ICD2 debugger environment.
#include <18F6527.h>
#device *=16 ADC=8 //16bit pointer, 8-bit ADC
//#fuses HS,NOWDT,PROTECT,NOPUT,NOBROWNOUT //,NOLVP //High Speed, No WDT, Code PROTECT, No Brown Out
//#fuses HS //, WDT128
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=RS485)
#use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, STREAM=UART)
int8 i, j, k, x;
int32 ProgramStartAddress;
int16 const TK[] = {0x1234, 0x2345, 0x3456, 0x4567,
0x1234, 0x2345, 0x3456, 0x4567};
#define Buffer_MAX 32
int16 Buffer[Buffer_MAX];
void FlashRWTest()
for (i=0; i<32; i++) {
Buffer[i] = 0;
ProgramStartAddress = 0x5000;
erase_program_eeprom(ProgramStartAddress);
write_program_memory(ProgramStartAddress, TK, 64);
read_program_memory(ProgramStartAddress, Buffer, 64);
while (1);
#ORG 0x01000,0x1fff
FlashRWTest();
Posted: Mon Sep 25, 2006 12:28 pm |
0x1234, 0x2345, 0x3456, 0x4567, |
I don't think that the write function can accept a constant array.
This is what I'm seeing, from looking at the .LST file.
Try removing the 'const' keyword and see if it starts working.
Also, your #fuses and pre-processor statements need some
improvement. You don't need to specify 16-bit pointers.
PCH automatically uses them. That directive is for the PCM compiler.
You should also add the ERRORS directive to your hardware UART
declarations. Try this:
#fuses HS,NOWDT,PROTECT,NOPUT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, STREAM=RS485)
#use rs232(baud=9600, xmit=PIN_G1, rcv=PIN_G2, ERRORS, STREAM=UART)
leekp8
Flash program memory not working - 2 |
Posted: Mon Sep 25, 2006 8:15 pm |
After removing const, it works.
However, with
it gave
Executing: "C:\Program files\Picc\CCSC.exe" "flrwtest.C" +FH +DF +LN +T -A +M +Z +Y=9 +EA
*** Error 111 "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.C" Line 12(7,49): Unknown keyword in #FUSES "NOLVP"
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Tue Sep 26 10:12:53 2006
If I were to remove NOLVP,
it gave the following errors:
*** Error 111 "E:\ats\A900_WD\BusCard\FLRWTEST\flrwtest.C" Line 12(7,51): Unknown keyword in #FUSES "NOBROWNOUT"
BUILD FAILED: Tue Sep 26 10:14:06 2006
Please advice. |
