How do I send an ICMP packet?
TimC
PostPosted: Mon Sep 25, 2006 10:51 am     Reply with quote
Hi all,
I am using the CCS Embedded Ethernet Dev kit and there are 2 examples in chapter 10 on receiving a response from a ICMP ping packet but I have no idea on how to send a ping request.
My project is to increment the TTL value for several Ping requests going to the same destination. I should be able to trace my Ping route as the number of hops exceeds the TTL value.
Thank You
Tim C
erhan
PostPosted: Fri Dec 15, 2006 2:29 am     Reply with quote
How can we send ping?My ip address=10.0.0.10
   NODE_INFO PingDest;
   int PingData[]={'e','r','h','a','n',0};
   int16 SeqNo=0;
   PingDest.MACAddr.v[0]= MY_MAC_BYTE1;
   PingDest.MACAddr.v[1]= MY_MAC_BYTE2;
   PingDest.MACAddr.v[2]= MY_MAC_BYTE3;
   PingDest.MACAddr.v[3]= MY_MAC_BYTE4;
   PingDest.MACAddr.v[4]= MY_MAC_BYTE5;
   PingDest.MACAddr.v[5]= MY_MAC_BYTE6;
   PingDest.IPAddr.v[0]=10;
   PingDest.IPAddr.v[1]=0;
   PingDest.IPAddr.v[2]=0;
   PingDest.IPAddr.v[3]=25;
   //ping
         ICMPPut(&PingDest,ICMP_ECHO_REQUEST,&PingData[0],5,12,++SeqNo);
This code did'nt work.I am watching bus with ethereal.it says 10.0.0.10 ping request but it doesn't say 10.0.0.25 echo reply.
asmallri
PostPosted: Fri Dec 15, 2006 2:56 am     Reply with quote
There are a number of possible problems.
Ensure that the source MAC address of the outbound packet is a unicast MAC address
If the source MAC address unique?
Have you set the sunbet mask correctly?
Does the target have a personal firewall - if so is ICMP enabled (not blocked)?
Do you see an ARP request from the Target looking for the PIC? If so does the PIC respond?
Regards, Andrew
erhan
PostPosted: Fri Dec 15, 2006 3:18 am     Reply with quote
I know destination mac address so I don't have to do arp request.
I corrected my code like this
   NODE_INFO PingDest;
   int16 SeqNo=0;
   PingDest.MACAddr.v[0]= 0;
   PingDest.MACAddr.v[1]= 0x17;
   PingDest.MACAddr.v[2]= 0x31;
   PingDest.MACAddr.v[3]= 0x2E;
   PingDest.MACAddr.v[4]= 0x26;
   PingDest.MACAddr.v[5]= 0xD5;
   ICMPPut(&PingDest,ICMP_ECHO_REQUEST,&PingData[0],5,0,++SeqNo);
Anyway now I can send ping.But I want to do arp request to learn destination mac address automatically.How can I do this
erhan
PostPosted: Fri Dec 15, 2006 7:10 am     Reply with quote
this is the working ping code with arp request
void ping(IP_ADDR *IPAddr)
    NODE_INFO remoteNode;
    int PingData[]="abcdefghijklmnnopqrstuwxvyz12345";
    int i;
    static int SeqNo=0;
    remoteNode.IPAddr = *IPAddr;
    ArpResolve(&remoteNode.IPAddr.v[0]);
    for(i=0;i<6;i++)
      remoteNode.MACAddr.v[i]=Cache.MACAddr.v[i];
    ICMPPut(&remoteNode,ICMP_ECHO_REQUEST,&PingData[0],32,0,SeqNo);
in main
   NODE_INFO PingDest;
   ping(&PingDest.IPAddr.v[0]);
dpechman
PostPosted: Thu Mar 22, 2012 7:24 pm     Reply with quote
My ping stop working after I change another parts of the code and I cannot find the bug.
In icmp.c the MyTxBuffer is equal to INVALID_BUFFER.
If I bypass the avoid check the ping is sent and looks ok to the address that I have pointed to.
How is the right way to set the MyTxBuffer?
void ICMPPut(NODE_INFO *remote,
             ICMP_CODE code,
             BYTE *data,
             BYTE len,
             WORD id,
             WORD seq)
    ICMP_PACKET   packet;
    WORD ICMPLen;
   BUFFER MyTxBuffer;
   MyTxBuffer = MACGetTxBuffer(TRUE);
   // Abort if there is no where in the Ethernet controller to
   // store this packet.
   //if(MyTxBuffer == INVALID_BUFFER) <<==here is true
     // return;
