Microchip USB bootloader
NicolasC
PostPosted: Thu Sep 14, 2006 5:59 am     Reply with quote
Hi all
My hardware is now ok. It is based on http://pic18fusb.online.fr/wiki/wikka.php?wakka=UsbBootload with a 2550 instead.
I use Microchip Bootloader package ( http://www.microchip.com/stellent/groups/picmicro_sg/documents/devicedoc/en021827.exe ) modified for 2550.
I can read and erase 2550 memory with the provided PDFSUSB.exe
I tried to apply what I found in this topic
http://www.ccsinfo.com/forum/viewtopic.php?t=26705&highlight=bootloader+relocate and add the following code:
#if defined(__PCM__)
   #define LOADER_END   0x1FF
   #define LOADER_SIZE   0x1BF
#elif defined(__PCH__)
   #define LOADER_END   0x7FF
   #define LOADER_SIZE   0x6FF
#ifndef _bootloader
   #build(reset=LOADER_END+1, interrupt=LOADER_END+5)
   #build(reset=LOADER_END+2, interrupt=LOADER_END+9)
#org 0, LOADER_END
The code seems to correctly relocated a 0x800h
Is this modication is enought to be compatible with Microchip USB bootloader ?
Uploading the HEX file failed with "Failed to write CODE DATA".
Regards
NicolasC
Solved
PostPosted: Fri Sep 15, 2006 11:41 am     Reply with quote
The above code is enought to be compatible with Microchip bootloader
I added NOPBADEN,WRTB to my fuses to remove warning when loading the HEX file :
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOPBADEN,WRTB
I still have the Warning "Failed to write CODE DATA" and I still don't know what is related but it's operationnal Smile
Joven
PostPosted: Mon Sep 18, 2006 4:11 am     Reply with quote
Hi
you can put a simple exemple for make upload for the pic.
thanks
NicolasC
PostPosted: Thu Sep 21, 2006 3:44 pm     Reply with quote
The boot program is provided in the Microchip Bootloader package listed above.
Then add the code above to relocate you program outside of the boot zone.
Be carefull with the configuration bits as they must be compatible with the bootloader. Check the USB bootloader manual.
Regards
