wakaka
C Code explanation |
Posted: Wed Sep 20, 2006 2:00 am |
Code: | #include <string.h>
#include <stdio.h>
PID Function
The PID function is used in mainly
control applications. PIDCalc performs one iteration of the PID
algorithm.
While the PID function works, main is just a dummy program showing
a typical usage.
typedef struct PID {
double SetPoint; // Desired Value
double Proportion; // Proportional Const
double Integral; // Integral Const
double Derivative; // Derivative Const
double LastError; // Error[-1]
double PrevError; // Error[-2]
double SumError; // Sums of Errors
} PID;
PID
double PIDCalc( PID *pp, double NextPoint )
double dError,
Error;
Error = pp->SetPoint - NextPoint;
pp->SumError += Error;
dError = pp->LastError - pp->PrevError;
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error
+ pp->Integral * pp->SumError
+ pp->Derivative * dError
Initialize PID Structure
void PIDInit (PID *pp)
memset ( pp,0,sizeof(PID));
Main Program
double sensor (void) // Dummy Sensor Function
return 100.0;
void actuator(double rDelta) // Dummy Actuator Function
PID sPID; // PID Control Structure
double rOut; // PID Response (Output)
double rIn; // PID Feedback (Input)
PIDInit ( &sPID ); // Initialize Structure
sPID.Proportion = 0.5; // Set PID Coefficients
sPID.Integral = 0.5;
sPID.Derivative = 0.0;
sPID.SetPoint = 100.0; // Set PID Setpoint
for (;;) { // Mock Up of PID Processing
rIn = sensor (); // Read Input
rOut = PIDCalc ( &sPID,rIn ); // Perform PID Interation
actuator ( rOut ); // Effect Needed Changes
I not quite understand in some parts this code, can some explain on it??
1. Code: | double PIDCalc( PID *pp, double NextPoint )
double dError,
Error;
What is the pp?? *pp?
2. Code: | void PIDInit (PID *pp)
What is memset?
3. Code: | void main(void)
PIDInit ( &sPID ), wat is &sPID ??
sPID.Proportion , the '.' means???? |
Posted: Wed Sep 20, 2006 2:19 am |
Question 1 and 3 have to do with the concept of pointers, an important part of the C language. It would take a lot of text to explain the working of pointers here, every good C book will describe it in details.
A standard function supplied with every C-compiler. Again, check your C language books for a detailed explanation. |
