interrupt!
dos_santos_rj
interrupt!
PostPosted: Tue Sep 19, 2006 6:53 pm     Reply with quote
I need two interrupts in my code...
this is a piec of part of my interrupt code:
ext_int_edge(l_to_h ); //when pin change 0 to 1, go to ....
INT_EXT!
enable_interrupts(global);
enable_interrupts(INT_EXT);
///the first interrupt (L_to_H) I did it, but I wanted another (H_to_L) that makes a diferent function from the first one..but I couldnīt make it
HELP
using pic16f628a
Vlew
Charles Santos
libor
PostPosted: Tue Sep 19, 2006 8:48 pm     Reply with quote
short edge_flag;
INT_EXT
void ext_isr() {
  if (edge_flag) {
    ...do l_to_h things
  } else {
    ...do h_to_l things
ext_int_edge(l_to_h);
edge_flag = 1;         //set flag, so l_to_h code is executed in interrupt
or
ext_int_edge(h_to_l);
edge_flag = 0;        //clear flag, so h_to_l code is executed in interrupt
or checking the port itself would be also an option, no flag needed,
though might result false result when a short glitch occurs
INT_EXT
void ext_isr() {
  if (input(PIN_B0)) {
    ...do l_to_h things
  } else {
    ...do h_to_l things
[/code]
dos_santos_rj
PostPosted: Tue Sep 19, 2006 9:16 pm     Reply with quote
libor,
Thank your help!
I made the code already.
Vlew
Charles Santos
pattousai
PostPosted: Wed Sep 20, 2006 8:27 pm     Reply with quote
hi, sorry for bothering.
I'm doing a project that i want to use the exact same interrupt (pin change 0 to 1), but i don't quite understand it.
if someone can help me i'll be appreciated.
dos_santos_rj:
can you post or send me the whole code, or just quite enough for i understand how this interrupt goes??
thanks!!
