abaut memory
ferrarilib
abaut memory
PostPosted: Sun Sep 17, 2006 3:58 am     Reply with quote
Hallo i am doing my project with 877A but i dont can do more memory abaut :
ROM used: 5798 words (71%)
Largest free fragment is 2048
RAM used: 200 (54%) at main() level
316 (86%) worst case
Stack: 9 worst case (7 in main + 2 for interrupts)
if i add same new line in my code the compiler write me not enougt rom memory .... with not all memory for example 99%... but max 74% .
I dont understand why .
I must use new pic with more memory for example 452 ?
thanks ..
PostPosted: Sun Sep 17, 2006 4:04 am     Reply with quote
Do a search on the forum for 'not enough memory'.
No, you don't need to use a larger chip. You just need to 'split up' what you are doing. The chip has a limit of how large a single 'block' of code can be, as well as on the total size. It is this second limit you are hitting.
ferrarilib
PostPosted: Sun Sep 17, 2006 6:00 am     Reply with quote
thanks Ttelmah !
but i have tried same cange in my code but not cange nothing
first :
in main call i have do a partial code a functions example
main()
//code............
//ecc
with :
main ()
function1();
function2();
but dont cange nothing in memory .
always:
this 316 dont cange :(
thanks
PostPosted: Sun Sep 17, 2006 6:29 am     Reply with quote
You need to declare the functions as _separate_.
If a function is only called a few times, the compiler will default to inlining them, which makes them part of the single 'main' block.
A search on the forum, will find detailed posts of how to split things up.
