thinnawut
My Serial Communicate is Not receive |
Posted: Fri Sep 15, 2006 2:05 am |
My module can recieve command or data about 3 Hour first. after 3 hour it cannot recieve all data.
Hel[ me please.
rgd.
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,enable=PIN_b5,bits=8,stream=RS485) // Jumpers: 8 to 11, 7 to 12
#define RS485_RX_BUFFER_SIZE 64
#define RS485_USE_EXT_INT TRUE
#include <stdlib.h>
#byte portb = 6 // PORTB Register
#PRIORITY ext,rda
#include <string.h>
#include <input.c>
/*********************** Interupt Serial **********************/
#int_rda
void rs232_isr()
string_in[next_in]=fgetc(RS485);
if(strcmp(string_in[next_in],'*')==0){next_in=0;}
if(strcmp(string_in[next_in],'$')==0){input_status=true;}
next_in=next_in+1;
if(next_in==20)next_in=19;
/*********************** End Interupt Serial ********************/
enable_interrupts(GLOBAL); // Enable Global Interrupts
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA); // Enable External Interrupts
set_tris_b(0x01); // Set TRISB RB1-RB7 output, RB0 input
set_tris_a(0);
set_tris_d(0);
while(TRUE) {}
Posted: Fri Sep 15, 2006 2:39 am |
You set interrupt priority, but only show one interrupt.
Add 'errors' to your S232 setup line. If something else (not shown), such as the 'ext' handler, prevents the serial bing handled in time, without this, the UART will lockup.
Set the tick box 'Disable HTML in this post', when posting code, otherwise parts of it will not be visible (such as what files you are including).
You have set 'RS485_USE_EXT_INT' to true, which means "don't use the RS232 hardware", yet the code you show is to use this hardware...
String compare functions, are quite slow, if the string has any length. When the buffer fills, what is ensuring that the string terminator is still present?. Avoid doing this sort of work in the interrupt handler (this may well be what is hanging the UART). Check the individual _character_, not the whole string.
thinnawut
I am no clear. |
Posted: Mon Sep 18, 2006 12:48 am |
Sorry.If you have some Examp I will it beter. I m not clear.
Thanks.
rgd. |
