220 VOLT OR 110 VOLT
ccmcca
PostPosted: Wed Sep 13, 2006 2:36 pm     Reply with quote
How can i drive OR TEST 220 v ???
I need a TRIAC? I need a solenoid?
Has anybody same example circuit?
THANKS.-
John Morley
PostPosted: Wed Sep 13, 2006 3:07 pm     Reply with quote
What do you mean by "drive or test 220V"? Do you mean how can you switch or control 220V with a PIC? If so, you'll need to use a mechanical or solid-state relay to do it. The PIC will then control the state of the relay. If that's not your question, can you elaborate some more - possibly with a description of your application?
John Morley
wakaka
PostPosted: Wed Sep 13, 2006 6:44 pm     Reply with quote
i think wat he means is drive an AC load with PIC....THink u need a triac. Try the MOCXXXX ( forget the part number), can googled it to get more info....
butterfly
PostPosted: Thu Sep 14, 2006 1:56 am     Reply with quote
you must look
microchip web site and search for x10 (home automation comminication protokol via 220 v line)
you will find what you need...(power supply,zero croos dedector...)
and yor triac can be bta 41 and of course you mus use an optodiac to use your triac...
