RTC Issue with PIC16F877A
Eleengnrng
PostPosted: Wed Sep 13, 2006 2:17 pm     Reply with quote
Ok here is the issue i am using a 20Mhz clock and i am using timer one on to count the number of clock cycles to equal 1 second. no problem there. once a complet minute happens it enter a function that decraments the a value and displays on a seven gegment display. the issue is that some where when i tell it to start to count down it hangs up when switching back and forth from some set conditions. BELOW IS A BUNCH OF CODE. HELP IS NEED FAST.
#include <16F877A.h>
#device adc=8
#FUSES NOWDT, HS, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#include <stddef.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdlibm.h>
#define Timer_LOC  0x00 // Timer data Location 5
#define Temp_LOC   0x06 // Temp Data Location 10 EEprom
#define XTAL_FREQUENCY  20000000
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 4)      // 1 clock tick = 1 instr. cycle = crystal frequency / 4
/*                          Global Variables                              */
int8 STSP=0,digit,sec=0,tempsetp=0,tempsetpm,acttemp=0;
int8 offsethigh,offsetlow,timera,timerb,timerval = 0;
int32 Ticker;
int8 Seconds=0, Choice=1, rawtemp;
int32 dispR = 458752, dispH = 1245184;
/*                  Functions & Function Delcarations                     */
void Initialize_RTC(void)
  if (Choice == 1)
      Ticker = TIMER1_FREQUENCY-dispR;        // initialize clock counter to number of clocks per second
  if (Choice == 2)
      Ticker = TIMER1_FREQUENCY-dispH;        // initialize clock counter to number of clocks per second
  setup_timer_1( T1_INTERNAL | T1_DIV_BY_1 ); // initialize 16-bit Timer1 to interrupt
                                              // exactly every 65536 clock cycles
                                              // (about 76 times per second)
  enable_interrupts( INT_TIMER1 );            // Start RTC
void Scroll_MSG();  // look at end of the code beyond Main Program
void Ready_MSG();   // look at end of the code beyond Main Program
//void digman(int8 value, int8 dvalue); //look at end of code beyond main program
/*                 END Functions & Function Delcarations                  */
/*                       Interupts Section Begins                         */
#int_RB
void RB_isr(){
//MONITORS SOME BUTTONS
   }//Port b on change int routine for temp setting
/*                    External interupt                                      */
#int_EXT
Void Ext_isr(){
   disable_interrupts(INT_EXT);
   digit=timerval;//input timer data
   delay_ms(10);
      If ((STSP==0)&&(input(PIN_B0)==0)){//if equal to 0 then its in start mode
         if ((STSP == 0)&&(input(PIN_B0)==0)){
         stsp=stsp+1;//increment stsp
         digman(digit,0);//load dig manipulation function with timer data
         //output_low(Pin_A4);//turn timer buzzer off
         Initialize_RTC();
         lcd_goto(2,16);
         printf(write_LCD,"%c",0x78);
      }else if ((STSP!=0)&&(input(PIN_B0)==0)){//if equal to 1 then its in stop mode
         stsp=0;//set STSP back to start position
         disable_interrupts( INT_TIMER1 );            // disable RTC
         timerval = digit;
         lcd_goto(2,16);
         printf(write_LCD,"%c",0x20);
         output_C(timerval);
         output_low(Pin_A4);//turn off buzzer
   enable_interrupts(INT_EXT);
}//External int routine for Timer
/*                       Timer 1 Interupt                                    */
#int_TIMER1
void TImer1_isr()
   disable_interrupts(INT_TIMER1);
  Ticker -= 65536;                        // Decrement ticker by clocks per interrupt
  if ( Ticker < 65536 )                   // If second has expired
  {  Ticker += TIMER1_FREQUENCY;          //   Increment ticker by clocks per second
     seconds++;                           //   Increment number of seconds
  Initialize_RTC();
   if (Choice == 1){
   if((Seconds == 60)) {digman(0,1); Seconds=0;}
   if (Choice == 2){
   if((Seconds == 30)) {digman(0,1); Seconds=0;}
} // End of timer 1 interup
#int_TIMER2
Void TIMER2_ISR(){
   disable_interrupts(INT_TIMER2);
   rawtemp = tempact();
   acttemp = rawtemp;
/*   if (rawtemp<=70){
   acttemp = rawtemp-10;
   }else if (rawtemp>70){
   acttemp = rawtemp;
   /*rawtemp = tempact();
   if (rawtemp > acttemp+3){
   acttemp = tempact();
   }else if ((rawtemp < acttemp-3) && (acttemp != 0)){
/*                        End Of Interupt Section                          */
/*                          Begin Main Program                             */
   SET_TRIS_A (0x01); //set reg a for temp sensor input
   SET_TRIS_B (0xf1); //Misc Data Pins
   SET_TRIS_C (0x00); //Set Port C to Outputs
   SET_TRIS_D (0x00); //LCD Data Port
   SET_TRIS_E (0x00); //LCD Control Port
   port_b_pullups(TRUE);
   setup_adc_ports(RA0_ANALOG);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   //setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   setup_timer_2(T2_DIV_BY_16,240,13);
   ext_int_edge(H_TO_L);//activate on high to low
   enable_interrupts(INT_RB);
   LCD_init();//Intilize the LCD Display
   set_adc_channel(0);//set A-D converter channel to 0
   output_low(Pin_A4);//turn buzzer off
   if (READ_EEPROM(Timer_LOC) != 0xff)
   timerval = READ_EEPROM(Timer_LOC);
   if (READ_EEPROM(Temp_LOC) != 0xff)
   tempsetp = READ_EEPROM(Temp_LOC);
   set_tris_c(0x00);//set port c for all outputs
   output_c(timerval);
   delay_ms(10);
   While(True){
      lcd_goto(1,1);
      printf(write_LCD,"%3u",tempsetp);//Display the temperature set point
      lcd_goto(1,4);
      printf(write_lcd,"%c",0x0df); //degree symbol
      lcd_goto(1,5);
      printf(write_lcd,"%c",0x43);  //Celcius
      offsethigh=tempsetp+3;
      if (tempsetp != 0)
         {offsetlow=tempsetp-6;}
      lcd_goto(1,12);
      printf(write_LCD,"%3u",acttemp);//Display the temperature
      lcd_goto(1,15);
      lcd_goto(1,16);
      if (STSP==0) {output_c(timerval);} //output Timer Val if timer not active
      if (acttemp>=tempsetp&&acttemp<offsethigh){
         output_low(Pin_A5);
         Choice = 1;
         ready_msg();
      }else if (tempsetp == 0){
         output_low(Pin_A5);
         Choice = 1;
         ready_msg();
      }else if ((acttemp==tempsetp)||(acttemp>offsetlow)){
         output_low(Pin_A5);
         Choice = 1;
         ready_msg();
      }else if (acttemp<=offsetlow){
         while (acttemp<=offsethigh){
         output_high(Pin_A5);
         Choice = 2;
         scroll_msg();
         lcd_goto(1,1);
         lcd_goto(1,4);
         lcd_goto(1,5);
         if (tempsetp != 0)
        lcd_goto(1,12);
         lcd_goto(1,15);
         lcd_goto(1,16);
/*      if ((decval == 0)&&(STSP == 1)){
         output_high(PIN_A4);
         delay_ms(8000);
      if (read_eeprom(Timer_LOC) != timerval)
         {write_eeprom(Timer_LOC,timerval);}
      if (read_eeprom(Temp_LOC) != tempsetp)
         {write_eeprom(Temp_LOC,tempsetp);}
} // End Of Main ***************************************************************
/*                             End Of Main                                 */
/*                           Begin LCD Functions                           */
void Scroll_MSG(){
//DISPLAYS HEATING MESSAGE
}//eng of scroll function
void Ready_MSG(){
// DISPLAYS READY MESSAGE
}// End of Ready Function
I left out chunks of code becasue i think that it not part of my problem and i only want.
PostPosted: Wed Sep 13, 2006 2:23 pm     Reply with quote
I think this project is done already and posted in the Code Library
by ckielstra.
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
Eleengnrng
PostPosted: Wed Sep 13, 2006 2:46 pm     Reply with quote
yes i have seen this code and modled my code after it. it works great the problem is that it seems to hang up when the main part of the function which i sum how cut out switchs betuween ready and scroling msg.
here is the missing Main Code.
   setup_spi(FALSE);
   output_c(timerval);
   delay_ms(10);
   While(True){
      lcd_goto(1,1);
      lcd_goto(1,4);
      lcd_goto(1,5);
      if (tempsetp != 0)
      lcd_goto(1,12);
      lcd_goto(1,15);
      lcd_goto(1,16);
      if (acttemp>=tempsetp&&acttemp<offsethigh>offsetlow)){
         output_low(Pin_A5);
         Choice = 1;
         ready_msg();
         Choice = 2;
         scroll_msg();
         lcd_goto(1,1);
         lcd_goto(1,4);
         lcd_goto(1,5);
         if (tempsetp != 0)
        lcd_goto(1,12);
         lcd_goto(1,15);
         lcd_goto(1,16);
         delay_ms(8000);
/*                             End Of Main                                 */
Sorry for the length in code but this problem has been aggravating and persistant every time i think that i have fixed it it appears again. so there is something that i am missing. I am figureing that a new pair of eys will help the problem out. thanks for any assistance.
PostPosted: Wed Sep 13, 2006 2:57 pm     Reply with quote
Can you edit your first post, and re-post the code, but this time click
on the box below the posting that says:
    X   Disable HTML in this post
The reason is that if you leave HTML turned on, then all lines of code
that have "greater than", and "less than", etc., get messed up.
For example, the "TImer1_isr()" code is screwed up.
Also, after you've done that, can you post a short comment on
exactly what line of code does it hang up on.
PostPosted: Wed Sep 13, 2006 3:28 pm     Reply with quote
You didn't post the code of your interrupt handlers. I see you enable 4 interrupts, please make sure you implemented functions for handling these interrupts. The compiler will not complain about a missing interrupt function, but when the interrupt occurs (accidently) it will not get cleared and loop forever; the PIC appears to stall.
