creativity Guest
| 16f877, ccs, adc, serial communication |
Posted: Wed Sep 13, 2006 12:55 am |
hi,
i want to read two analog input and after converting them to dijital, i will sent them to serial port one by one. i have writen the following code but something is wrong, do you have any idea?
// ADC and Serial Communication //
// 2 channel Analog Input //
// 1 channel serial digital RS232 output//
// Ali Özgür Argunşah //
// argunsah@su.sabanciuniv.edu //
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
long int input1;
setup_adc_ports(ALL_ANALOG);
//delay_ms(2000);
do {
set_adc_channel(0);
delay_cycles(60);
input1 = read_adc();
putc(input1);
set_adc_channel(1);
delay_cycles(60);
putc(input1);
} while(TRUE);
Posted: Wed Sep 13, 2006 1:11 am |
What do you mean by "something is wrong" ?
Tell us what you expect to see, and what you are actually seeing. |
creativity Guest
Posted: Wed Sep 13, 2006 1:43 am |
I expect to read the serial output of 16f877 with a matlab code given below. I gave a sinus signal to one input and zero to the second one. i expect to see a sinus with some zeros inside (one sin signal and one zero, and so on) but i only see some random signal. as you see more than "something" is wrong
s1 = serial('COM3', 'BaudRate', 9600,'Databits',10);
fopen(s1);
eye=zeros(512*2,1);
for i=0:1
eye(i*512+1:i*512+512) = fread(s1)
% plot(eye)
end
plot(eye);
fclose(s1); |
Posted: Wed Sep 13, 2006 2:46 am |
How many Databits should there be?...
creativity Guest
Posted: Wed Sep 13, 2006 3:57 am |
i changed code to the code below and it works:
#include <16F877.h>
#device adc=8
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8) // Jumpers: 8 to 11, 7 to 12
long int input1;
//delay_ms(2000);
do {
set_adc_channel(0);
delay_cycles(60);
putc(input1);
set_adc_channel(1);
delay_cycles(60);
putc(input1);
} while(TRUE);
thank you for all replies. |
