boatdrinks Guest
| 18F4620 with a "Slow Internal Osc" |
Posted: Tue Sep 12, 2006 9:21 am |
I have a PIC18F4620 that i am trying to use with it's internal OSC set to 8MHZ. For some reason it seems that the delay_ms(250); is taking close to a minute to execute. I set the program up using the PIC Wizard. Any insight would be greatly appreciated.
thanks,
[void main()
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,249,1);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(FALSE);
do
output_high(PIN_E1);
delay_ms(250);
output_high(PIN_E2);
delay_ms(250);
output_low(PIN_E1);
delay_ms(250);
output_low(PIN_E2);
delay_ms(250);
}while(TRUE);
#include <18F4620.h>
#device adc=8
#FUSES INTRC_IO //Internal RC Osc
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for low-power operation
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)][/code] |
libor
Posted: Tue Sep 12, 2006 9:26 am |
instead of
try it with
setup_oscillator(OSC_8MHZ); |
boatdrinks Guest
| thanks... |
Posted: Tue Sep 12, 2006 9:34 am |
Thanks Libor....
I did that and it's working like a champ.
90 minutes of hair pulling... one line of code.
Yup, it's going to be one of those days......
thanks again! |
