I have 3.236 on my Gateway SOLO laptop and it runs fine. When I change to 3.249, I get errors and PCW.exe will not even start. I can't remember the error, something to do with the graphics, gradients... I can reinstall 3.236 and all works again. Has anyone seen this.... It has Windows NT installed. Service Pack 6.
kam
Posted: Fri Sep 08, 2006 2:57 pm
I have seen this many times! My fix ends up being uninstalling CCS 100%, then reinstalling. So far that has worked for me...
I'm on version 3.234, and I'm staying there since it is kind of stable....unless you use the pow method (returns wrong values), or try using 4xpll with setup_osc method (does not set up 4x correctly)...or...!
