Breno
Joined: 20 Jul 2006 Posts: 5 Location: Belo Horizonte, Brazil
Two PICs communicating in SPI |
Posted: Fri Sep 08, 2006 1:25 pm |
Hi everybody,
I was simulating something in Proteus and it worked perfectly. But when I was going to test it for real it didn't work very well: there is a 4MHz crystal in the OSC1 and OSC2 pins but the osciploscope can't see 4MHz there, there is nothing showing in the LCD display but some LEDs are working. Can someone tell me what's wrong?
This system works communicating the two PIC's through SPI and using a LCD. I will post the scheme of the simulation later.
Here it is the code for the master one:
Code: | // Configure chip and compiler
#include "16F877A.h"
#fuses XT,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP
#zero_ram
// #byte PORTA = 5
// PORTA is a variable mapped to the 8 physical pins of port A of the PIC
#define CS PIN_D2
#define DI PIN_C5
#define DOUT PIN_C4
#define CLK PIN_C3
void escreve(void);
int x=0;
int dado[8];
// Variables
// Configure pin direction
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
set_tris_a(0b11011111);
set_tris_b(0b11111111);
set_tris_c(0b10010111);
set_tris_d(0b11111011);
port_b_pullups(1);
output_high(PIN_C6);
output_high(PIN_A5);
// Setup the SPI port
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4);
// spi_write(0x00);
// spi_write(0x00);
if(input(PIN_B0) == 0)
strcpy(dado, "01003355");
escreve();
while(input(PIN_B0) == 0);
else if(input(PIN_B1) == 0)
strcpy(dado, "02002715");
escreve();
while(input(PIN_B1) == 0);
void escreve()
for(x=0;x<8;x++)
output_low(PIN_A5);
delay_us(10000);
spi_write(dado[x]);
delay_us(10000);
And this is for the Slave one:
#include "LCD.c" // ENTRE "" OU <> ? CONFIRMAR!!!
#fuses XT,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP,NOWRT // NOMCLR e INTRC_IO nao compilam!
#zero_ram
// #byte PORTA = 5
int data[8];
int bus1[8];
int bus2[8];
char x=0;
int c=0;
void ext_isr(void);
void escreve_horario(void);
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
set_tris_a(0b11111111);
set_tris_b(0b11111011);
set_tris_c(0b11011111);
output_high(PIN_B2);
setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_CLK_DIV_4);
// init interrupts
ext_int_edge( H_TO_L ); // seta a int ext para borda de descida
enable_interrupts(INT_EXT);
clear_interrupt(INT_EXT);
// Inicializa LCD
lcd_init();
for(;;)
if(x==8)
x=0;
c=data[1];
if(c=='1')
// strcpy(bus1, data);
lcd_putc('\f');
lcd_putc("4111: ");
escreve_horario();
else if(c=='2')
// strcpy(bus2, data);
lcd_putc('\f');
lcd_putc("4501: ");
escreve_horario();
#INT_EXT
void ext_isr(void)
data[x]=spi_read(0);
x++;
lcd_putc(data[2]);
lcd_putc(data[3]);
lcd_putc(':');
lcd_putc(data[4]);
lcd_putc(data[5]);
lcd_putc(':');
lcd_putc(data[6]);
lcd_putc(data[7]);
Breno
Posted: Fri Sep 08, 2006 1:46 pm |
Here it is the schematic:
Each of those two buttons, when pressed, will make the Master send a different message via SPI to the Slave PIC. The Slave PIC will then show the message in the display.
