Guide request about my code(timers and other errors)
Moeini
PostPosted: Tue Sep 05, 2006 2:36 am     Reply with quote
Hi
I want to send Data from a transmitter board to a receiver.
kindly attend to following explanations :
1- my PIC is 16f877a
2- my crystal is 7.68MHz
3- a binary '1' is represented by a 1ms burst of 120kHz at the zero crossing point of the AC line and a binary '0' by the absence of 120kHz.
my transmitter code is:
#include <trans1.h>
///////////////////////////My_LCD2\\\\\\\\\\\\\\\\\\\\\\\\
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rw; // access to the LCD pins.
BOOLEAN rs; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
#byte lcd = 0xF81 // This puts the entire structure
#else
#byte lcd = 0xF83 // This puts the entire structure
#else
#byte lcd = 6 // on to port B (at address 6)
#else
#byte lcd = 8 // on to port D (at address 8)
#define set_tris_lcd(x) set_tris_b(x)
#else
#define set_tris_lcd(x) set_tris_d(x)
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
////////// lcd_read_byte() \\\\\\\\\\\
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
////////// lcd_send_nibble(n) \\\\\\\\\\\\
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n )
int8 x;
BYTE low,high;
lcd.rs = 0;
do
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
x = (high<<4>> 4); \\
lcd.data = n>>4;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
// lcd_send_nibble(n & 0xf); \\
lcd.data = n & 0xf;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
// lcd_send_nibble(3);
lcd.data = 3;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
delay_ms(5);
// lcd_send_nibble(2);
lcd.data = 2;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
int8 t;
BYTE low,high;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
// lcd_send_byte(0,0x80|address);
/////// lcd_send_byte(address,n)\\\\\\
lcd.rs = 0;
do
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
t = (high<<4>> 4); \\
lcd.data = (0x80|address)>>4;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
lcd.data = (0x80|address)& 0xf;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
void lcd_putnum(int8 i)
// lcd_putc((i/10)+0x30);
lcd_send_byte(1,(i/10)+0x30);
i %= 10;
// lcd_putc(i+0x30);
lcd_send_byte(1,i+0x30);
void lcd_putday(int8 day)
switch (day)
case 0: lcd_send_byte(1,'S');
lcd_send_byte(1,'A');
lcd_send_byte(1,'T');
// lcd_putc("SUN");
case 1: lcd_send_byte(1,'S');
lcd_send_byte(1,'U');
lcd_send_byte(1,'N');
// lcd_putc("SUN");
case 2: lcd_send_byte(1,'M');
lcd_send_byte(1,'O');
// lcd_putc("MON");
case 3: lcd_send_byte(1,'T');
lcd_send_byte(1,'E');
// lcd_putc("TUE");
case 4: lcd_send_byte(1,'W');
lcd_send_byte(1,'D');
// lcd_putc("WED");
case 5: lcd_send_byte(1,'T');
lcd_send_byte(1,'H');
// lcd_putc("THU");
case 6: lcd_send_byte(1,'F');
lcd_send_byte(1,'R');
lcd_send_byte(1,'I');
// lcd_putc("FRI");
#define PIN_Xin PIN_C3
#define Falling 1
#define Rising 0
//Global Variables
int1 X10TxFlag, X10RxFlag;
int1 RxBit,TxBit;
int1 TxCommandFlag=1,RxCommandFlag,SecondTxFlag;
int TXData3=0,TxData2=0,TxData1=0,TxData0=0;
int RxData3=0, RxData2=0, RxData1=0, RxData0=0;
int checkstart1=0,checkstart2=0;
int RxFunction=0,RxUnit=0,Rxkey1=0,Rxkey2=0,RxHouse2=0,RxHouse1=0;
int NumTxBit,count;
int w,w1,w2,w3,w4,w5;
int1 ext_edge=Falling,ZX;
int8 i=10,ZxCount,seconds;
int keys;
int1 j=0,k=0,X10AddressSent=0;
int RxHouse,xor,TxHouse,TxUnit,TxFunction;
int16 ADC_Average=0;
int8 ADC_Counter=0;
int8 KBH();
void TransmitX10Bit();
void RotateTxData(int w);
void ZeroCrossing();
void InitX10Tx();
void InitZerocrossingDetect();
void ShowCodeTx();
void ToggleInterruptEdge();
void ControlX10Units();
#byte trisc=0x87
#bit Xout=trisc.2
#bit t0if=0xb.2
#bit intf=0xb.1
#byte status=0x3
#bit carry=status.0
#bit zerro=status.2
#int_EXT
EXT_isr()
TransmitX10Bit();
//********************* ReceiveX10Bit*************************
//called at every ZC .
//if 120khz is present (Xin=1), set the RxBit otherwise,clear the RxBit.
if(X10TxFlag==0) //if transmit is done RxBit=0.
{RxBit=0;}
RxBit=input(PIN_Xin); //else RxBit=Xin.
if(X10TxFlag==1) //If X10TxFlag is set,transmit is begin. then,performe X10Tx.
//***************** X10Tx() ******************
//Transmit 22 bits of data out of TXData registers
//Rotate by 10 to reposition TXData
//Transmit 28 bits of data out of TXData registers
TxBit=bit_test(TxData3,7);
carry=TxBit;
#asm
rlf TxData0,f
rlf TxData1,f
rlf TxData2,f
rlf TxData3,f
#endasm
NumTxBit--;
if(NumTxBit ==0) //Have all the bits been sent?
if(SecondTxFlag==0)//Yes, was this the second transmission?
SecondTxFlag=1;//No, set up for second transmission and
//Set the flag to indicate second transmission.
w=10;
RotateTxData(w);//Reposition data at left end of buffer.
NumTxBit=28; //Send 22 bits again.
X10TxFlag=0; //If X10TxFlag is clear, then last transmit is done.
///////// X10Rx() \\\\\\\\\\\
carry=RxBit;
#asm
rlf RxData0,f //Rotate the received data into the RxData registers.
rlf RxData1,f
rlf RxData2,f
rlf RxData3,f
#endasm
checkstart1=RxData3 & 0b00001111; //Check for the Start Code '1110'
checkstart2=checkstart1 ^ 0b00001110;
if(checkstart2==0) //Is the start code present?
// When Start Code is detected in RxData3 [xxxx1110]
//perform the below operations:
RxHouse2=RxHouse1;
Rxkey2=Rxkey1;
RxHouse1=RxData2;
Rxkey1=RxData1;
w1=RxHouse1^RxHouse2; //Do last two received house codes match?
if(w1==0)
w2=Rxkey2^Rxkey1; //Do last two received key codes match?
if(w2==0)
w3=RxData0 & 0b11000000; //Check for the Unit address suffix '01'
w4=w3 ^ 0b01000000;
if(w4==0) //Is the Unit address suffix present?
RxUnit=Rxkey2;
RxCommandFlag=0; // Yes, then address has been received.
X10RxFlag=1; //If X10RxFlag is set, then data has been received.
w5=w3 ^ 0b10000000; //check for Function suffix.
if(w5==0) //Is the Function suffix present?
RxFunction=Rxkey2;
RxCommandFlag=1; //yes,Set command received flag.
#int_TIMER0
TIMER0_isr()
EndX10Envelope:
Xout=1; // disable 120khz output
disable_interrupts(INT_timer0);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,15,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(32L);
setup_vref(FALSE);
enable_interrupts(INT_EXT);
lcd_init();
lcd_gotoxy(1,1);
lcd_putc("X10 THERMOSTAT");
keys=0;
while (keys==0) keys=KBH();
switch(keys)
case 2:
lcd_gotoxy(1,2);
lcd_putc("setpoint:");
i++;
if (i==35){ i=10;}
lcd_gotoxy(11,2);
lcd_putnum(i);
case 4:
lcd_gotoxy(1,2);
if (i==10) {i=35;}
i--;
lcd_gotoxy(11,2);
lcd_putnum(i);
case 8:
w=4;
RotateTxData(w);
ShowCodeTx();
case 16 :
lcd_putc('\f');
lcd_gotoxy(1,1);
lcd_putc("ControlX10Units");
ControlX10Units();
case 32 :
while (1)
if (X10TxFlag==0) InitX10Tx();
VOID InitX10Tx()
TxData3=0b00001110; //load TxData3 with start code.
TxData2=TxHouse; // house code
if(TxCommandFlag==1) //is the transmit command flag set?
TxData1=TxFunction; //yes,then prepare to transmit command.
TxData0=0b10000000;
TxData1=TxUnit; //no,then prepare to transmit an address.
TxData0=0b01000000;
w=4;
RotateTxData(w); //rotate the TxData registers 4 times to
// the left to prepare for transmission.
NumTxBit=22; //set number of bites to transmit.
SecondTxFlag=0;
X10TxFlag=1; // Set the X10TxFlag to begin transmission.
void ShowCodeTx()
int i;
lcd_putc('\f');
lcd_gotoxy(1,1);
lcd_putc("TxData: ");
for (i=0;i<8;i++)
lcd_putc(0x30 + bit_test(TxData3,7-i));
lcd_gotoxy(1,2);
for (i=0;i<8;i++)
lcd_putc(0x30 + bit_test(TxData2,7-i));
for (i=0;i<8;i++)
lcd_putc(0x30 + bit_test(TxData1,7-i));
for (i=0;i<8;i++)
lcd_putc(0x30 + bit_test(TxData0,7-i));
//********************TransmitX10Bit************************
//called at every ZeroCrossing.
//if TxBit=1,enable 120khz output for 1ms otherwise, do nothing.
VOID TransmitX10Bit()
if(TxBit ==0)
RxBit=0;
Xout=0; //enable 120khz output.
set_timer0(0xe2);//??
enable_interruptS(INT_timer0);
RxBit=1;
TxBit=0;
if(X10AddressSent==0) //has address been sent?
TxHouse=0b01101001; //no, then send address.
TxUnit=0b01101001;
TxCommandFlag=0; //clear the TxCommandFlag for sending address.
InitX10Tx();
X10AddressSent=1;
X10TxFlag=1; //Set the X10TxFlag to begin transmission.
TxHouse=0b01101001; //yes, then send command.
TxUnit=0b01010110;
InitX10Tx();
X10AddressSent=0;
int8 KBH()
int8 keys=0;
if(!input(PIN_B1)) keys+=2;
if(!input(PIN_B2)) keys+=4;
if(!input(PIN_B5)) keys+=8;
if(!input(PIN_B4)) keys+=16;
if(!input(PIN_B3)) keys+=32;
if(keys!=0)
return(keys);
return 0 ;
void InitZeroCrossingDetect()
ext_int_edge(H_TO_L);
enable_interrupts(INT_ext);
//*******************ToggleInterruptEdge***********************
//Toggles interrupt edge so that interrupt are generated
// on both rising and falling zero-crossings on RB0/INT pin.
if (ext_edge == Falling)
ext_int_edge(L_TO_H);
ext_edge++;
count=w;
for (i=0;i<w;i++)
carry=bit_test(Txdata3,7);
#asm
rlf TxData0,f
rlf TxData1,f
rlf TxData2,f
rlf TxData3,f
#endasm
my receiver code is:
#include <receiver1.h>
#define Falling 1
#define Rising 0
//Global Variables
int1 RxBit,TxBit;
int NumTxBit,count;
int keys;
int8 ADC_Counter=0;
void InitX10Tx();
void EndX10Envelope();
void ControlDevice();
#byte trisc=0x87
#bit Xout=trisc.2
#bit t0if=0xb.2
#bit intf=0xb.1
#byte status=0x3
#bit carry=status.0
#bit zerro=status.2
#int_EXT
EXT_isr()
/////// ReceiveX10Bit\\\\\\\\\
if(X10TxFlag==0){RxBit=0;}
if (RxBit==1)
output_low(PIN_A1);//turn on LED.
carry=RxBit;
#asm
rlf RxData0,f
rlf RxData1,f
rlf RxData2,f
rlf RxData3,f
#endasm
if(checkstart2==0)
RxHouse2=RxHouse1;
Rxkey2=Rxkey1;
RxHouse1=RxData2;
Rxkey1=RxData1;
w1=RxHouse1^RxData2;
if(w1==0)
w2=Rxkey2^Rxkey1;
if(w2==0)
w4=w3 ^ 0b01000000;
if(w4==0)
RxUnit=Rxkey2;
RxCommandFlag=0;
X10RxFlag=1;
w5=w3 ^ 0b10000000;
if(w5==0)
RxFunction=Rxkey2;
RxCommandFlag=1;
X10RxFlag=1;
#int_TIMER0
TIMER0_isr()
EndX10Envelope();
{ setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
set_pwm1_duty(32L);
setup_vref(FALSE);
enable_interrupts(INT_EXT);//?????????????
InitX10Tx();
InitZerocrossingDetect();//ext_int_edge(H_TO_L);
if(X10RxFlag==1)
{ControlDevice();}
RxHouse= RxHouse2;
if(RxCommandFlag==1)
RxFunction=Rxkey2;
X10RxFlag=0;
xor=RxFunction ^ 0b01010110;
if(xor==0)
{output_low(PIN_A2);}
RxUnit=Rxkey2;
X10RxFlag=0;
TxUnit=0b01101001;
InitX10Tx();
X10AddressSent=1;
TxUnit=0b01010110;
InitX10Tx();
X10AddressSent=0;
VOID InitX10Tx()
TxData3=0b00001110;
TxData2=TxHouse;
TxData1=TxFunction;
TxData0=0b10000000;
TxData1=TxUnit;
TxData0=0b01000000;
w=4;
RotateTxData(w);
NumTxBit=22;
SecondTxFlag=0;
X10TxFlag = 1;
enable_interrupts(INT_ext);//???????????????????????????
ext_edge++;
count=w;
for (i=0;i<w;i++)
#asm
rlf TxData0,f
rlf TxData1,f
rlf TxData2,f
rlf TxData3,f
#endasm
please guide me about the above mentioned early and point out me errors of this.
Best Regards.
