How can i concate the 8 bits of the struc to one var
The Puma
PostPosted: Sun Sep 03, 2006 1:26 pm     Reply with quote
// Defines seconds register (RESET STATE: ???? ????)
struct {
byte UNITS_BCD :4; // Unit seconds BCD format
byte TENS :3; // Ten seconds, 0 to 5 binary
byte NOT_UNUSED :1; // NOT USED
} SECONDSREG;
time[0]=hexd2decD(SECONDSREG.TENS);
time[1]=hexd2decD(SECONDSREG.UNITS_BCD);
Now there are two 8 bit vars (time[0]+time[1])
How can i put these together on one var (time[0])
PostPosted: Sun Sep 03, 2006 1:35 pm     Reply with quote
See the make16() function in the CCS manual.
The Puma
PostPosted: Sun Sep 03, 2006 1:41 pm     Reply with quote
Thats make an 16bit value
But i need an 8bit var
UNITS_BCD = 4 bit
TENS = 3 bit
NOT USED = 1 bit
I will concate the 3 types together and put it in an 8 bit variable
time[0]
PostPosted: Sun Sep 03, 2006 2:25 pm     Reply with quote
OK, I guess I misread your post.
It looks like you could use bcd2bin() to convert SECONDSREG to
an 8-bit integer. Example:
int8 result;
result = bcd2bin(SECONDSREG);
// This function converts an 8 bit BCD value to
// an 8 bit binary value.
// The input range must be from 00 to 99.
char bcd2bin(char bcd_value)
char temp;
temp = bcd_value;
// Shifting the upper digit right by 1 is
// the same as multiplying it by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
