36Khz Square Wave on 16f628A
uNO
PostPosted: Fri Sep 01, 2006 10:58 am     Reply with quote
I'm trying to obtain a 36khz square wave with a duty cycle of 50% on a Pic 16f628A clocked by an external crystal at 10Mhz.
This is the code that I'm Using
#include <16F628A.h>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP ,NOMCLR
#use delay(clock = 10000000)
   setup_ccp1(CCP_PWM);
   set_timer0(0);
   setup_timer_2(T2_DIV_BY_1, 68, 1);
   set_pwm1_duty(34);
   enable_interrupts(INT_RTCC);
If I simulate with Proteus it give me 36Khz but when I try on a circuiit at home ... It doesn't works.
I need the 36 Khz to turn on and off an Ir Led for a proximity detector, I made a circuit with ne555 and it works greatly, Why it doesn't work with pic ? I'm quite sure that I made a mistake in the code. Please help me.
PostPosted: Fri Sep 01, 2006 11:26 am     Reply with quote
You don't have an interrupt service routine for the RTCC.
You're not even using the RTCC. You're using PWM.
Delete the two lines shown in bold below:
set_timer0(0);
set_pwm1_duty(34);
uNO
Still not Working.
PostPosted: Sat Sep 02, 2006 4:02 pm     Reply with quote
I've Tryed to remove the wrong lines of code but it is still not Working. The cause cannot be the circuit considering that with the square wave generated by the ne555 it works fine. At this point I'm quite sure that I'm making one ore more mistake in the code, but I can't figure where. Please help me.
PostPosted: Sat Sep 02, 2006 4:30 pm     Reply with quote
The NE555, can drive several hundred mA (typically 200mA). The PIC only 25mA. Try running the PIC without your load...
PostPosted: Sat Sep 02, 2006 8:21 pm     Reply with quote
The result of calling set_pwm1_duty differs depending on the parameter type you pass to it, an int8 or int16. I find this very confusing; parameter overloading is an object oriented feature, not something you expect in a C-compiler.
I tried to understand the different results of calling
set_pwm1_duty(34);
or
set_pwm1_duty(34L);
The generated code is different but I didn't quiet get it. Maybe someone else can tell me which version is giving the expected result of a 50% duty-cycle?
PostPosted: Sat Sep 02, 2006 11:23 pm     Reply with quote
See near the end of this thread. I was looking for one of my old
explanations and I discovered Ttelmah has got a better one:
http://www.ccsinfo.com/forum/viewtopic.php?t=24055
PostPosted: Sun Sep 03, 2006 7:30 am     Reply with quote
Thanks PCM, that was the information I was looking for.
uNO
Still In troubles
PostPosted: Mon Sep 04, 2006 1:36 pm     Reply with quote
Thank you for your interest. The current to turn the Led On isn't flowing in the pic but on a transistor so the Mistake cannot be in the excessive current on the pic. The sensor works good with the Remote control of the Tv So the mistake cannot be in the receiver module. I've no more ideas.
PostPosted: Mon Sep 04, 2006 1:50 pm     Reply with quote
Post your compiler version.
To find the version, look at the top of the .LST file in your project folder.
The version will be a 4-digit number such as 3.191, 3.236, 3.249, etc.
uNO
Finally It works
PostPosted: Tue Sep 05, 2006 1:05 pm     Reply with quote
Without no more Ideas i started to replace all of the component on my testing circuit and replacing the crystal all started to work properly. I don't have great experience in building circuit but it's the first time that I see something like this.
Thank you all !
