Darryl Groom Guest
Convert float to long int |
Posted: Fri Aug 01, 2003 2:34 am |
Does anybody have a decent routinr to convert a 32-bit floating point number back to a 16-bit lon integer?
___________________________
Original Post ID: 144516544 |
IK1WVQ Guest
re |
Posted: Fri Aug 01, 2003 3:58 am |
<font face="Courier New" size=-1>:=Does anybody have a decent routinr to convert a 32-bit floating point number back to a 16-bit lon integer?
simply:
float a=123.89;
int16 b;
b = (int16)float; // its all!!!
the value of A must not be greater than 0xffff, off course!!
regards..
</font>
Original Post ID: 144516546 |
Sherpa Doug Guest
Re: Convert float to long int |
Posted: Fri Aug 01, 2003 6:43 am |
What is wrong with casting?
float f;
long i:
i = (long)f;
Original Post ID: 144516547 |
R.J.Hamlett Guest
Re: re |
Posted: Fri Aug 01, 2003 10:55 am |
:=<font face="Courier New" size=-1>:=Does anybody have a decent routinr to convert a 32-bit floating point number back to a 16-bit lon integer?
:=simply:
:=float a=123.89;
:=int16 b;
:=b = (int16)float; // its all!!!
:=the value of A must not be greater than 0xffff, off course!!
:=regards..
The 'downside' of the cast, is that it can give problems, when dealing with numbers beyond the maximum range of the smaller type. I used the following, when I had to have a 'friendly' handling of this behaviour:
union lblock {
unsigned int16 ui[2];
signed int16 i[2];
int8 b[4];
signed int32 word;
//Trims an incoming 32bit value to a 16bit value
signed int16 trim16(union lblock val) {
if (val.b[3] & 0x80) {
//Here -ve
if ((val.ui[1] != 0xFFFFl) || !(val.b[2] & 0x80))
val.word=0xffff8000l;
else {
if ((val.ui[1]) || (val.b[2] & 0x80)) val.word=0x7FFFl;
return(val.i[1]);
Call the function with a normal signed int32, as the variable (the 'union', allows the individual bytes to be accessed internally. This 'trims' anything above the maximum range for the signed int16.
Casting is easier, and quicker, if you know that the range of the incoming value is acceptable.
Original Post ID: 144516560 |
