/* Now the SSP handler code. Using my own, since the supplied routines test the wrong way round for my needs */
#DEFINE READ_SSP() (SSPBUF)
#DEFINE WAIT_FOR_SSP() while((SSPSTAT & 1)==0)
#DEFINE WRITE_SSP(x) SSPBUF=(x)
#DEFINE CLEAR_WCOL() SSPCON=SSPCON & 0x3F
A emulation of the spi_write function, would be:
WRITE_SSP(value);
WAIT_FOR_SSP();
However I wanted the two operations to be seperate, since I can then write a character, let the hardware 'get on' with doing the transfer, and only test that a transfer has completed when I next need to write, with:
WAIT_FOR_SSP(); //Test last transfer has completed
value=READ_SSP(); //retrieve last transfer if required
WRITE_SSP(new_value); //and start the next transfer.
theteaman
Posted: Wed Aug 30, 2006 8:35 am
Thank you very much ttelmah! I will use these macros and hopefully it all works!! (I was sure I saw this code of yours somewhere else on the forum but i couldnt remember how i found it witht the 'search' function).
