first time using a PIC
pattousai
PostPosted: Wed Aug 23, 2006 2:45 pm     Reply with quote
hi everybody.
i'm trying to do my first compilation with a PIC (12f629). So i write the following code, just to see how things go:
#include <12F629.h>
#fuses INTRC_IO, NOWDT,PUT,BROWNOUT,NOMCLR
main(){
if( 2 + 2 == 4)
output_high(PIN_A0);
when i try to burn with IC-prog they return the error "value of the calibration of the oscillator". and ask me if i don't want to replace for the value in the file (don't know what this means). then, i just ignore that and click yes. but in the end they return the error "verification failed in the adress 0000h".
i'm using the ccsc compiler to compile (of course) and the IC-prog to burn in the pic.
well, sorry for the bad english and i hope for any help
thanks!!!
PostPosted: Wed Aug 23, 2006 3:40 pm     Reply with quote
These two threads discuss the problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=27234&highlight=icprog+osccal
http://www.ccsinfo.com/forum/viewtopic.php?t=12208&highlight=icprog+osccal
On the ic-prog website, it says:
Added support for PIC 12F family.
IMPORTANT: Please read out your PIC 12F and store the file safely.
This way you have a backup of your OSCCAL and BANDGAP values!
http://www.ic-prog.com/main.html
http://www.rcgroups.com/forums/archive/index.php/t-247247.html
These are just a few of the links I found by using http://www.google.com
Do a search for these keywords: icprog OSCCAL
pattousai
PostPosted: Fri Aug 25, 2006 3:52 pm     Reply with quote
ok, thanks. i will do some reading
