'Endianness' of multibyte variables
thomasj50
PostPosted: Wed Aug 23, 2006 10:40 pm     Reply with quote
I seems that the CCS compiler uses 'little endian' encoding of 16 and 32 bit variables, i.e. the least significant byte is stored first (at the lowest address), which Intel/Microsoft also does. Is there anyone that can confirm this ?
Best Regards,
Thomas Johansson
PostPosted: Wed Aug 23, 2006 11:30 pm     Reply with quote
You can confirm it yourself by compiling a test program and looking
at the .LST file.
#include <16F877.h>
int32 temp;
temp = 0x44332211;
Note the 0x11 is the LSB and 0x44 is the MSB.
.................... int32 temp;
.................... temp = 0x44332211;
000C:  MOVLW  44
000D:  BCF    03.5
000E:  MOVWF  24
000F:  MOVLW  33
0010:  MOVWF  23
0011:  MOVLW  22
0012:  MOVWF  22
0013:  MOVLW  11
0014:  MOVWF  21
From the symbol table:
021-024 main.temp
thomasj50
Endianness
PostPosted: Thu Aug 24, 2006 12:18 am     Reply with quote
Well, perhaps I could have confirmed it myself if I had understood the PIC assembler :-) I guess I am one of the few that went directly to C programming with this processor, after having spent 30 years digging trough assembler listings.
It is confirmed then ?
Best Regards.
Thomas J
libor
PostPosted: Thu Aug 24, 2006 2:41 am     Reply with quote
Yes, confirmed. You can also check it understanding pure C only:
long temp;
int *ptr;
temp = 0x2211;
ptr = &temp;
if (*ptr == 0x11) printf("LSB is stored first\r\n");
future
PostPosted: Tue Sep 05, 2006 8:45 pm     Reply with quote
How would you solve the problem to read little endian streams mapped to a struct?
I have some programs with hard-coded offsets and I am willing to make them more readable...
Thank you.
