Help!! SPI conn between 2 PICs
PostPosted: Wed Aug 23, 2006 6:46 pm     Reply with quote
I am working on a SPI communication between 2 PICs
18F452 is Master
16F873 is Slave
I have the master code working, but I can not get the slave to work. I know master code is working because I have an Assembler code per MICROCHIP SPI tutorial in the slave. Confirmed that work, but I want to have it in CCS C instead of assembler.
How to get the data from the master?
CAn any body helP?
Here is my code:
Slave Code:
Example code demonstrates SPI connection between 2 PICs (18F452
and 16F876).
Master sends data (a counter), Slave receives and outputs to
LEDs on PORTB
#include <16F873.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
int data;
   //Ports Initialization
   set_tris_a(0x3F);            // PORTA to inputs
   set_tris_b(0x00);            // PORTB to outputs
   set_tris_c(0x18);            //Set SDO to output, SCK &  SDI to input
   setup_ADC_ports(NO_ANALOGS);   //Turn off A/D ports, all
                           //porta will be use as digital
   //SPI configuration
   setup_spi(spi_slave | spi_h_to_l | spi_clk_div_16);
      // Test to see if data transfer complete?
      if(!input(PIN_A5));
      //Get data
      data = spi_read();
      output_b(data);
Here is the Master Code:
and 16F876).
LEDs on PORTB
#include <18F452.h>
//Defined Chip Select PIN
#define SS   PIN_A2
//Global Variables
int counter,data;
   //Reset counter to 0
   counter = 0;
   set_tris_a(0x00);            // PORTA to outputs
   set_tris_c(0x10);            //Set SCK & SDO to output & SDI to input
   //SPI configuration
   setup_spi(spi_master | spi_h_to_l | spi_clk_div_16);
      //Enable Chip Select pin (LOW)
      output_low(SS);
      //Send Data (counter) to Slave
      spi_write(counter);
      while(!spi_data_is_in());
      //get data (does not use at this time
      data=spi_read();
      //Disable Chip Select PIN (HIGH)
      output_high(SS);
      //Update counter
      counter ++;
      //Delay routine so human eyes can see the flash
      Delay_ms(100);
Please help...
PostPosted: Wed Aug 23, 2006 7:03 pm     Reply with quote
By the way just to clear, the comment said that I use the 876 but actually
I do use the 16F873 as the slave
PostPosted: Wed Aug 23, 2006 7:14 pm     Reply with quote
Sample code for SPI slave:
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
