pic can only get analog date 10 bit. i want to use over simpling and over avaraging.. I found a way using nyquist theory.. i use adc module like:
#device adc=10
for over avaraging can i use like that:
#device adc=12
thanks for help
SherpaDoug
Posted: Wed Aug 23, 2006 7:48 am
You will have to roll your own oversampling and averaging. To get 2 more bits you need 16 samples IF there is GAUSSIAN RANDOM noise. In practice I find this works poorly because the noise is often not quite random and never really gaussian.
However it is easy enough to try, just sum 16 samples and divide by 4 and see what you get. _________________ The search for better is endless. Instead simply find very good and get the job done.
kender
