HELP WITH I2C PIC16F690
henry
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Mon Aug 21, 2006 8:17 am     Reply with quote
HELLO,
I was looking for information in all topics about I2C and I still can't solve my problem.....
I'm trying to comunicate 2 PIC16F690 with I2C, 1 Master and 1 Slave, but i don't know what is the problem with my code......the 'ACK' bit sometimes is received and sometimes isn't.
START
1st byte - adress
2nd byte - data
3rd byte - data
STOP
Sometimes the master reveceives 3 'ACK', 1 per bit.....and doesn't receive the 'NACK'......othewise there are no any 'ACK'.
The 'ssp_handler' routine in the SLAVE is like Microchip's one.
Henry
PostPosted: Mon Aug 21, 2006 9:07 am     Reply with quote
Without looking too deeply, there are two big problems 'leaping out', which are connected.
You are using the 'INT_SSP' defintion, which inherently implies that the _compiler_ will have allready 'added' the interrupt register saves, before this code is called. You then save the registers inside your routine, which is both unnecessary (given that the compiler has already done this), and takes _time_. Now you send bytes immediately following one another. Given the time delays in the interrupt handling (worse in C, because of the number of registers involved), and especially given your code effectively 'saving' the registers twice, the slave just does not have time to actually handle it's 'end' of the transaction...
You need to make a decision, whether you are going to use the existing assembler SSP handler, and the assembler register saving (which should only be used together, and without _any_ C in the routines), in which case, your interrupt handler, needs to be defined as 'int_global', or use the C approach, in which case a lot of the routine can be thrown away, since the compiler has already done the necessary register saving. However the 'ssp_handler' routine you are using, needs a _lot_ of extra registers saved (it is using array accesses, and a switch statement in particular), so going to assembler, would involve a lot of work.
Look at the CCS example I2C slave routine, which shows how to handle this, and slow down the master transactions a little, and you may then have a chance.
henry
PostPosted: Tue Aug 22, 2006 1:43 am     Reply with quote
Hello everybody,
Now, i changed my code and i can send and receive correctly the 3 bytes i want...
START
delay....
1st byte - Address
delay...
2nd byte - data
delay...
3rd byte - data
delay...
STOP
The problem is that i'm not receiving the NACK at the end of the last byte.
How the MASTER sends a NACK???
Henry
MASTER
#if defined(__PCM__)
#include <16F690.h>
#device ADC=10
#fuses HS, NOPROTECT, NOBROWNOUT, NOMCLR, NOCPD, NOWDT, PUT, NOIESO, NOFCMEN
#use rs232(baud=19200, xmit=PIN_B7, rcv=PIN_B5, BITS = 8 )
#use i2c(MASTER, sda=PIN_B4, scl=PIN_B6, SLOW=100000 )
/////////////////////////////////FUNCIONES//////////////////////////////////////
#include "inicializacion.c"         //Config. inicial de todos los registros
#include "puerto_serie.c"           //On serial port, off serial port....
///////////////////////////////////MAIN/////////////////////////////////////////
void  main()
   delay_cycles( 1 );
   output_a(0b00000000);                  //Latch del puerto a 00
   output_b(0b00000000);                  //Latch del puerto a 00
   output_c(0b00000000);                  //Latch del puerto a 00
   delay_cycles( 1 );
   set_tris_a(0b11111111);                //All I/O ports as inputs
   set_tris_b(0b11111111);
   set_tris_c(0b11111111);
   delay_cycles( 1 );
   puerto_serie_off();     //Serial port off
   inicializacion();       //Inicializacion general de registros
   delay_ms( 1000 );
   do
      i2c_start();            //start bit
      delay_cycles( 50 );
      i2c_write(0xa0);        //Send slave address
      delay_cycles( 50 );
      i2c_write(1);           //Send first data
      delay_cycles( 50 );
      i2c_write(40);          //Send second data
      delay_cycles( 50 );
      i2c_stop();             //Stop bit
      delay_ms( 1000 );       //delay
      delay_cycles( 50 );
      delay_cycles( 50 );
      i2c_write(2);           //Send first data
      delay_cycles( 50 );
      i2c_write(80);          //Send second data
      delay_cycles( 50 );
      delay_cycles( 50 );
      delay_cycles( 50 );
      i2c_write(3);           //Send first data
      delay_cycles( 50 );
      i2c_write(120);          //Send second data
      delay_cycles( 50 );
   }while( TRUE );
SLAVE
#include <16F690.h>
#device ADC=10
#use i2c( SLAVE, SDA=PIN_B4, SCL=PIN_B6, address=0xa0, SLOW=100000 )
#include "ssp_handler.c"
////////////////////////////////INTERRUPCIONES//////////////////////////////////
#INT_SSP NOCLEAR
void ssp_interupt ()
   ssp_handler();
   bit_clear( SSPSTAT_R, 0);  //Clear flag buffer full
   bit_clear( SSPCON_R, 6);   //Clear flag Overflow
   bit_clear( SSPSTAT_R,7 );  //Must be clear
void  main()
   delay_cycles( 1 );
   output_b(0b10000000);                  //PIN TX puerto serie a alto
   output_c(0b00000000);                  //Latches del puerto a 00
   delay_cycles( 1 );
   set_tris_a(0b00001111);
   set_tris_b(0b01111111);
   delay_cycles( 1 );
   delay_ms( 100 );
   puerto_serie_tx();
   printf("start");
   buffer_full = 0;
   bit_clear( PIR1_R, 3 );    //Clean interrupt flag
   bit_clear( SSPCON_R,5 );   //reset ssp module
   delay_cycles( 5 );
   bit_set( SSPCON_R,5 );     //reset ssp module
   delay_cycles( 5 );
   enable_interrupts(INT_SSP);
   do
      if(buffer_full == 1)
         buffer_full = 0;
         printf("%u,%u\n\r",buffer_i2c[ 0 ], buffer_i2c[ 1 ]);
   }while( TRUE );
SLAVE FUNCTIONS
//SSP_Handler
// The I2C code below checks for 5 states:
// State 1: I2C write operation, last byte was an address byte.
// SSPSTAT bits: S = 1, D_A = 0, R_W = 0, BF = 1
// State 2: I2C write operation, last byte was a data byte.
// SSPSTAT bits: S = 1, D_A = 1, R_W = 0, BF = 1
// State 3: I2C read operation, last byte was an address byte.
// SSPSTAT bits: S = 1, D_A = 0, R_W = 1, BF = 0
// State 4: I2C read operation, last byte was a data byte.
// SSPSTAT bits: S = 1, D_A = 1, R_W = 1, BF = 0
// State 5: Slave I2C logic reset by NACK from master.
// SSPSTAT bits: S = 1, D_A = 1, R_W = 0, BF = 0
// For convenience, WriteI2C and ReadI2C functions have been used.
//////////////////////////////VARIABLES GLOBALES////////////////////////////////
   int   buffer_i2c[0x02];        //Data buffer
   int   address_i2c;             //address i2c
   int   buffer_full;
//////////////////////////////////ssp_handler.c/////////////////////////////////
void ssp_handler()
   int SSPSTAT_TEMP  = 0;           //Auxiliar register for SSPSTAT
   int incoming      = 0;
   SSPSTAT_TEMP   = SSPSTAT_R & 0b00101101;  //Masking bits unuseful on SSPSTAT
   switch ( SSPSTAT_TEMP )
                                    //State 1
      case 0x09:                    //Write operation,last byte was address,
      {                             //buffer is full
         buffer_i2c[ 0 ] = 0;       //clean  data buffer
         buffer_i2c[ 1 ] = 0;
         address_i2c = 0;           //Clean address i2c
         incoming = i2c_read();     //Read byte received
         bit_clear( PIR1_R, 3 );    //Clean Interrupt flag
                                 //State 2
      case 0x29:                 //Write operation, last byte was data,
      {                          //buffer is full
         buffer_i2c[ address_i2c ] = i2c_read();//Received byte to buffer
         address_i2c++;                         //++ buffer address
         if( address_i2c >= 2)
            buffer_full = 1;
                                 //State 3
      case 0x0C:                 //Read operation, las byte was address,
      {                          //buffer empty
         i2c_write(buffer_i2c[address_i2c]);    //Write byte in SSPBUF
                                 //State 4
      case 0x2C:                 //Read operation, last byte was data,
      {                          //buffer empty
                                 //Estado 5
      case 0x28:                 //NACK receive when transmiting data
         printf("todo ok\n\r");
      default:                   //ERROR
         delay_cycles( 5 );
         printf("todo ko\n\r");
rnielsen
PostPosted: Tue Aug 22, 2006 12:54 pm     Reply with quote
If the Master is writing to the slave then it's the slave that sends the ACK/NOACK back to let the master know if the information was received okay. The only time the master sends the ACK/NOACK to the slave is if the master is Reading from the slave. This tells the slave if the master is still going to want more data or if it's done reading from the slave. The NOACK is sent on the Last read that is sent from the master by sending the command:
variable = i2c_read(0);
The zero(0) sends the NOACK to the slave at the end of the read sequence.
Ronald
PostPosted: Wed Aug 23, 2006 12:14 am     Reply with quote
Thanks,
Now i have a tested I2C for 2 PIC16f690 (MASTER - SLAVE) at 100kbps. anyone who needs the code just ask Smile.....
henry
PostPosted: Wed Aug 23, 2006 12:16 am     Reply with quote
Thanks,
PostPosted: Wed Jun 13, 2007 10:08 am     Reply with quote
henry wrote:
Thanks,
Yes, Thank-you, would you send me the code? I too am using the 690s.
Please send to
ebarnes@islandhideaway.net
Thanks in advance.
Ed.
