I2C slave address 7 bit vs 10 bit
PostPosted: Sat Aug 19, 2006 10:12 am     Reply with quote
I have a master I2C talking to a salve.
I'm having problems with the salve address.
My slave is set to 0x12 as follows:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x12, FORCE_HW)
It however only communicates with the master when the master sets the address to 0x1E.
Do I have a problem with 7 bit vs 10 bit addressing modes?
Thanks for your time
Jeff
PostPosted: Sat Aug 19, 2006 11:01 am     Reply with quote
I fixed the problem by relocating
This brings me to my next question. I have a backplane that can hold 7 slaves. The salves address is determined by the solt postion of the backplane. I have a subroutine that reads the slot position and then sets the slave address. This routine was causing my first problem EVEN THOUGH I NEVER CALLED the routine!
Is this a compiler problem?
switch (slotID)
case 0:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x10, FORCE_HW)
case 1:
case 2:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x14, FORCE_HW) break;
case 3:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x16, FORCE_HW)
case 4:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x18, FORCE_HW)
case 5:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x1a, FORCE_HW)
case 6:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x1c, FORCE_HW)
case 7:
#use I2C(slave, sda=PIN_B4, scl=PIN_B6, address=0x1e, FORCE_HW)
PostPosted: Sat Aug 19, 2006 2:04 pm     Reply with quote
You canīt do that. #use is a pre-processor directive, so the last one found in the source code will be the one that works. Try to change the slave address wrtiting directly to the respective register.
PostPosted: Sat Aug 19, 2006 7:10 pm     Reply with quote
Thanks!
I'll give it a shot.
PostPosted: Mon Aug 21, 2006 5:18 am     Reply with quote
Code is now working
#BYTE SSPADD = 0x93
SSPADD = i2cSlotAddress[slotID]; // load slave address
