Hi anyone has a sample code
Jakin
PostPosted: Tue Aug 15, 2006 6:52 pm     Reply with quote
Hi, All:
Do you have a sample code for RS485 Master and slave ?
Could you please post it if you have one ? Thank you very much ~!
Regards,
Jakin
kender
MODBUS
PostPosted: Tue Aug 15, 2006 7:05 pm     Reply with quote
Look for MODBUS protocol in this forum. MODBUS is a higher level protocol designed to operate on the RS485 physical layer. The MODBUS spec is free.
For example:
http://www.ccsinfo.com/forum/viewtopic.php?t=18412
Jakin
ModBUS
PostPosted: Wed Aug 16, 2006 2:54 pm     Reply with quote
Hi,All:
what does ModBus stands for ? I am new on this type of term. Please give some information. Thank you very much
Regards,
Jakin
rwyoung
PostPosted: Wed Aug 16, 2006 3:06 pm     Reply with quote
There is code for 9-bit RS485 type transmissions in the examples or driver directory of a full compiler install. May not be there for the student edition.
http://www.modbus.org/, Google is your friend...
Rob Young
kender
Re: ModBUS
PostPosted: Wed Aug 16, 2006 3:34 pm     Reply with quote
You can find a brief description of Modbus and a bunch of related links here
http://en.wikipedia.org/wiki/Modbus
Jakin
PostPosted: Wed Aug 16, 2006 4:05 pm     Reply with quote
Well, I do not know that I am using ModBus or not. I do know I will use MPLab to be my complier. So do you know where I can find any sample code for RS485? Thank you very much.
Thanks again,
Jakin
PostPosted: Wed Aug 16, 2006 6:14 pm     Reply with quote
MPLAB is not a compiler but what's called an Integrated Development Environment (IDE). Here you edit and debug your code, it also calls an compiler but as an external application. You can integrate the CCS compiler in MPLAB, but also other compilers like Microchip C18, IAR or Bytecraft are possible compilers.
When you are asking for an example it matters which compiler you are using. C is a standardized language but for the small embedded processors like the PIC is the compiler vendors have added some library functions to access the hardware that are not standardized. Porting code from one compiler to the other is sometimes more difficult than starting from scratch.
Why are you insisting on using RS485? It is only a standard for hardware interconnection and you can run any protocol on it you like. You were given the MODBUS example code, tell us why it isn't good for you so we know what direction to point you. Is it too complex? Do you have multiple devices connected to your RS485 or is it just point-to-point connection?
Jakin
PostPosted: Thu Aug 17, 2006 1:26 pm     Reply with quote
Hi,All:
The problem is how to use RS 485 to be multi-masters and slaves connection. In order to get my job done, I just do not know how I should use rabbit BL2500 to communicate with PIC16F648A. I know that I need to develop a C programming to drive the Masters and slaves. But what else I need to consider.
Jakin
PostPosted: Thu Aug 17, 2006 3:46 pm     Reply with quote
Hi, All;
Does anyone know that PIC can support RS 485 ? I did not see any Library which is used for RS485.
PostPosted: Thu Aug 17, 2006 4:16 pm     Reply with quote
Bookmark the following page. It shows a list of all examples, drivers,
and ".H" files for CCS. Look at this page if you have questions about
what files CCS provides. Do a search of this page for "RS485":
http://www.ccsinfo.com/devices.php?page=exlist
In addition to that, use http://www.google.com
Bookmark Google. Make it your home page. Do a search on Google
for these keywords: PIC RS485
You will got lots of hits.
kender
PostPosted: Thu Aug 17, 2006 4:27 pm     Reply with quote
Please correct me if I'm wrong, but none of the PICs directly support RS 485. RS485 is connected to the PIC's uart through an interface chip such as MAX485
There are PICs with hardware support for CAN. If you are designing a system from scratch (as opposed to interfacing to an existing RS485 bus), consider CAN.
Mark
PostPosted: Thu Aug 17, 2006 5:01 pm     Reply with quote
Jakin wrote:
Hi,All:
Are you to do the BL2500 code as well, or is it already done? If it is done, then you must get the protocol for the other device. RS485 is not a protocol and there are an infinite number of ways to communicate using RS485.
jakin
PostPosted: Fri Aug 18, 2006 3:59 pm     Reply with quote
Hi, Mark
I just want to know how to develop the C code . Do you have any sample code. If you do, please post it. Thank you so much
Mark
PostPosted: Fri Aug 18, 2006 9:11 pm     Reply with quote
I suggest that you get yourself some C manuals and books on programming micros and start reading.
