Problem with SPI - PIC16F687
vinims
View user's profile Send private message MSN Messenger ICQ Number
PostPosted: Wed Aug 16, 2006 6:41 am     Reply with quote
When I try to write a byte on SPI, the program crashes.
Here is my code:
#include "16F687.h"
#fuses XT, NOWDT, PUT, NOMCLR, NOBROWNOUT, NOCPD, NOPROTECT, NOFCMEN, NOIESO
#use delay(clock=3686400)
#byte PORTA  = 0x05
#byte PORTB  = 0x06
#byte PORTC  = 0x07
#byte TRISA  = 0x85
#byte TRISB  = 0x86
#byte TRISC  = 0x87
#bit TEST    = PORTC.0
   TRISA = 0x08;
   TRISB = 0x30;
   TRISC = 0x00;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   PORTA = 0x00;
   PORTB = 0x00;
   PORTC = 0x00;
   while(true)
      TEST = 1;
      spi_write(0x55);
      delay_us(50);
      TEST = 0;
PostPosted: Wed Aug 16, 2006 7:39 am     Reply with quote
What is your compiler version?
How do you know your program crashes? You have no delay between setting TEST 0 to 1, so the output will be low for only a few clock cycles.
vinims
PostPosted: Wed Aug 16, 2006 8:22 am     Reply with quote
3.249
After spi_write(0x55) code line I was trying to send a byte through rs232 and I did not get any answer from PIC.
But if I comment spi_write(0x55) code line, it works perfectly.
