DEFINES for spi_setup
Goto page Previous  1, 2
PostPosted: Wed Aug 16, 2006 4:19 am     Reply with quote
You can either use the internal oscillator, at 10MHz, with the PLL, or just use an external oscillator. The pin will accept 40MHz as an input.
theteaman
PostPosted: Wed Aug 16, 2006 5:22 am     Reply with quote
Thanks ttelmah, i understand now.. the datasheet says 'Max Fosc=20MHz' (p343) but this must be under different conditions or something Confused
Page 2 of 2
