Using "FAST" Interrupt on PIC18
kuwa
PostPosted: Sun Aug 13, 2006 7:19 am     Reply with quote
When FAST keyward are used in #int_xxx, compiler outputs highpriority
interrupt code without saving registers.
The interrupt code is as follows.
0008:  MOVLB  0
000A:  GOTO   0138
.................... #int_timer2 FAST
.................... void isr_timer2(void) {
.................... #ASM
.................... MOVFF  0xFE0,07
0138:  MOVFF  FE0,07
.................... #ENDASM
013C:  BCF    F9E.1
013E:  RETFIE 1
At 0008, code is always MOVLB 0.
It may overwrite 0 to BSR whichi is using in main program.
It will make trouble.
Why the compiler output such code?
How should I do to stop outputting the code, "MOVLB 0"?
Mark
PostPosted: Sun Aug 13, 2006 7:40 am     Reply with quote
Read the datasheet on the PIC. Certain registers are saved by the PIC hardware.
PostPosted: Sun Aug 13, 2006 8:53 am     Reply with quote
The MOVLB instruction was added in v3.228 (or v3.227) to fix a bug where a C coded interrupt was assuming to be in bank zero by default. Placing the MOVLB instruction at the interrupt vector address is a quick-and-dirty fix. It works but in programs like yours where you don't access any C variables it adds an unwanted 1 instruction overhead.
Just curious, what do you have located at adres 0x0007? If this is a C variable that you dind't fix at this location with a #locate instruction, then the CCS generated code is actually just what you need.
More information on the bug fix: http://www.ccsinfo.com/forum/viewtopic.php?t=24950
kuwa
Thanks!
PostPosted: Mon Aug 14, 2006 8:37 pm     Reply with quote
>Mark
Oh! I had overlooked "Fast Regester Stack".
I should have noticed it,"RETFIE 1".
So, I understand no trouble will be.
Thank you.
kuwa
Thank you
PostPosted: Mon Aug 14, 2006 8:54 pm     Reply with quote
>ckielstra
Thank you for the explanation about the history.
And,it"s a interest Idea.
So,I tried it.
But, if I write follows,
#device HIGH_INTS=TRUE
#build (interrupt=0x07)
interrupts start at 0x07 and 0x17.
So I thought, and made as follows.
#build (interrupt=0x20)
#org 0x008,0x017
int_high_ent()
#asm
**** own code
BCF    0x***.*
RETFIE 1
#endasm
#org 0x018,0x01f
int_low_ent()
#asm
goto 0x30 // priority low entry
#endasm
I am able to want to do.
But,,, I know It's needless thing. Wink
Thank you very much.
Mark
PostPosted: Tue Aug 15, 2006 6:56 am     Reply with quote
The hardware will still jump to 0x08 and 0x18 and thus the 2 instructions at 0x07 and 0x17 will not get executed and thus not adding to the overhead.
kuwa
0x0016
PostPosted: Tue Aug 15, 2006 6:43 pm     Reply with quote
But, "MOVLB 0" for low priority interrupt is not 0x0016, as follows.
#build(interrupt=0x07)
0006:  MOVLB  0
0008:  GOTO   00AE
000C:  NOP
000E:  NOP
0010:  NOP
0012:  NOP
0014:  NOP
0016:  MOVFF  FE8,05
001A:  MOVFF  FD8,06
001E:  MOVFF  FE0,07
0022:  MOVLB  0
0024:  MOVFF  FE9,0D
0028:  MOVFF  FEA,08
002C:  MOVFF  FE1,09
So, It may have trouble, if it jump to 0x17(exactly 0x16).
Thank you.
