Using assembler in C source
unitrant
PostPosted: Fri Aug 11, 2006 3:17 am     Reply with quote
Can anyone suggest how I can alter the following assembler snippet so CCS compiler will like it, please?
incf   sRxTx_Pntr,F   // step the pointer
incf   sRxTx_Count,F   // step num chrs rcvd
movf   sRxTx_Pntr,W   // is pointer too far?
sublw   LOW sRx_BuffLimit   // check against limit address
btfsc   STATUS,0      // skip if greater (no ETX)
sRx_BuffLimit is defined as the address of the last byte in the sRxTx_Buffer which is Bank 2. The compiler doesn't like the use of LOW to get the lower byte of the address, which is all that is required here. So far my attempts to use C expressions to coerce it have failed.
I would like to avoid rewriting the code as it would, I think, get longert and this is a time critical interrupt handler.
PostPosted: Fri Aug 11, 2006 11:47 am     Reply with quote
Write a test program and look at the .LST file. What is it doing ?
It's only an 8-bit machine. What byte is it likely to be using ?
The answer in in the .LST file.
unitrant
PostPosted: Fri Aug 11, 2006 12:18 pm     Reply with quote
Thank you for your suggestion. The problem is that the compiler does not like any of my attempts to derive what is effectively an offset (8bit) from the base address of sRxTx_Buffer. Hence the code will not compile and no .lst file ensues.
I realise that the compiler has poor support for assembler code, not unreasonably, but I wanted to save converting this section of a reasonably sized assembler project until later. Probably easier to do it now after all.
PostPosted: Fri Aug 11, 2006 12:27 pm     Reply with quote
Look at the .LST file shown below for this test program:
#include <16F877.H>
#byte STATUS = 0x03
int8  sRxTx_Pntr;
int8  sRxTx_Count;
int16 sRx_BuffLimit;
#asm
sublw   sRx_BuffLimit  // check against limit address
#endasm
0000            00304 ... int8  sRxTx_Pntr;
0000            00305 ... int8  sRxTx_Count;
0000            00306 ... int16 sRx_BuffLimit;
0000            00307 ...
0000            00308 ... #asm
0000            00309 ... incf   sRxTx_Pntr,F
000C 1283       00310 BCF    03.5
000D 0AA1       00311 INCF   21,F
0000            00312 ... incf   sRxTx_Count,F
000E 0AA2       00313 INCF   22,F
0000            00314 ... movf   sRxTx_Pntr,W
000F 0821       00315 MOVF   21,W
0000            00316 ... sublw   sRx_BuffLimit
0010 3C23       00317 SUBLW  23
0000            00318 ... btfsc   STATUS,0
0011 1803       00319 BTFSC  03.0
0000            00320 ... #endasm
Symbols
main.sRxTx_Pntr                   00000021
main.sRxTx_Count                  00000022
main.sRx_BuffLimit                00000023
Neutone
Re: Using assembler in C source
PostPosted: Fri Aug 11, 2006 12:49 pm     Reply with quote
It's 8-bit. You cant increment a 16-bit pointer in a single instruction.
You don't have to specify the low byte because the instruction only operates on a single byte.
