SPI with 18F8722
mkr
SPI with 18F8722
PostPosted: Thu Aug 10, 2006 1:26 pm     Reply with quote
Hello All :)
I am going through a very hard time to setup MAX3110 with 18F8722 in SPI mode. I am using the second spi D4,D5,D6 pins.
I am not able to write and read the configuration data from max3110. When I write 0xc40a I should read back 0x4000.
When I read 0x4000 I should read back the current setting in the SSP2BUF. I am not able to. My f8722 is in master mode
Here are my init setup of ssp2.
[list=]
//These for a 18F chip
#define CS_LOW output_low(PIN_J1)
#define CS_HIGH output_high(PIN_J1)
#byte SSP2CON = 0xF63
#byte SSP2STAT = 0xF64
#byte I2C2BUF = 0xF65
#byte SSP2BUF = 0xF66
#define SSP2C_INIT 0x00
#bit SSP2EN = 0xF63.5
#define SSP2S_INIT 0x40
#bit BF = SSP2STAT.0
#bit SMP = SSP2STAT.7
#bit CKE = SSP2STAT.6
#bit CKP = SSP2CON.4
#bit SSPM3 = SSP2CON.3
#bit SSPM2 = SSP2CON.2
#bit SSPM1 = SSP2CON.1
#bit SSPM0 = SSP2CON.0
#define READ_SSP() (SSP2BUF)
#define WAIT_FOR_SSP() while(!BF)
#define WRITE_SSP(x) SSP2BUF = (x)
#define CLEAR_WCOL() SSP2CON = SSP2CON & 0x3F
void max3110_init(void){
SSP2BUF = 0x0000;
SSP2EN = 1;
SMP = 1;
CKE = 0;
CKP = 0;
SSPM3 = 0;
SSPM2 = 0;
SSPM1 = 0;
SSPM0 = 1;
// this is where i read and write operation to max3110
void max3110(void){
// Mconfig = 0xC40a;
CS_LOW;
WRITE_SSP(0xc4); // send msb
WAIT_FOR_SSP();
msb=READ_SSP();
WRITE_SSP(0x0a); // send lsb
WAIT_FOR_SSP();
lsb=READ_SSP();
CS_HIGH;
readconfig = ((unsigned short)msb << 8 | lsb);
delay_us(10);
CS_LOW;
WRITE_SSP(0x40); // send msb
WAIT_FOR_SSP();
msb=READ_SSP();
WRITE_SSP(0x00); // send lsb
WAIT_FOR_SSP();
lsb=READ_SSP();
CS_HIGH;
Is there any thing I am missing.
PLease help me
mkr
PostPosted: Thu Aug 10, 2006 2:54 pm     Reply with quote
One obvious thought. How have you got TRIS configured?. Remember if you are taking control of the SPI yourself, _you_ need to set the TRIS register toput the bits into the right mode. Check the chip data sheet for the required direction setting for the bits.
mkr
1 thing i noticed
PostPosted: Thu Aug 10, 2006 3:08 pm     Reply with quote
the tris_d is set accordingly. D4 is SDO, D5 is SDI, D6 is SCK so thats works out to be 0x20 for port D so that is set_tris_d(0x20)
The other thing i noticed is that the clock is not coming out of D6 pin. wondering why. any thoughts
mkr
PostPosted: Thu Aug 10, 2006 5:53 pm     Reply with quote
You shouldn't poll the BF flag:
29. Module: MSSP (SPI Mode)
In SPI mode, the Buffer Full Status bit, BF
(SSPxSTAT<0>), should not be polled in software
to determine when the transfer is complete.
Read more about this in the new revision C of the PIC18F8722 errata document and two possilble work arounds.
 SSP2BUF = 0x0000;
This is tricky: writing a 16 bit value to an 8 bit register. It is also possible the chip select line and SSP2 module are active at this point which causes you to wite data to the MAX3110.
I didn't have much time to study the MAX3110 datasheet but I think you have to change the SPI mode to CKP = 0, CKE = 1, SMP = 0,
mkr
Thanks for the thought, queries about CKP and CKE
PostPosted: Thu Aug 10, 2006 7:40 pm     Reply with quote
Thanks for your resource full reply. I looked at the f8722 errata. Your right. I should not poll for BF to change state.
Another thing about CKP and CKE. Based on MAX3110E data sheet, legal value for CKP =0 and CKE = 0. Is CPOL and CPHA same as CKP and CKE. I am getting confused. In the data sheet of MAX3110, CPOL =0 and CPHA=0 has to be set.
Your suggestion greatly appreciated
mkr
PostPosted: Fri Aug 11, 2006 3:02 am     Reply with quote
I can recommend you to read http://www.ucpros.com/work%20samples/Microcontroller%20Communication%20Interfaces%202.htm. This is a short article on several microcontroller Interfaces including SPI.
CPOL = Clock Polarity, it defines the clock's logic level in idle state. Working is identical to the Microchip CKP bit.
CPHA = Clock Phase, it defines on which clock edge the data is shifted out for sending and shifted in for reading. The Microchip CKE bit has the same functionality but... it is defined inverted, so CKE = ! CPHA.
See also http://www.ccsinfo.com/forum/viewtopic.php?t=8747
CPOL =0, CPHA = 0 translates to --> CKP = 0, CKE =1
SMP is always set to 0, only for some very rare non-standard communications it has to be set to 1.
mkr
perfect its working
PostPosted: Fri Aug 11, 2006 8:41 am     Reply with quote
Thanks a lot. I changed the CKE =1 and CKP =0 and also followed the errata for F8722 for BF on SSP2STAT.0. I am not polling this bit.[/quote]
mkr
